Question about Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo
How to take off the front of the tv to clean the glass
  • 537 Answers
Don't send me a chat request for something like this. I will not answer it unless you want to pay for support
Posted on Nov 20, 2007
My fireplace glass is cloudy and won't come clean?
this is all i can find out.
How to clean the glass of your Direct Vent Gas Fireplace
  1. Following the instructions in your manual, turn off the fireplace including the pilot light, and open the glass front.
  2. Leave the glass front on its hinges if on hinges. ...
  3. Use a cream cleanser like Imperial Gas Fireplace Glass Cleaner.
More items...
How to clean the glass on your Direct Vent Gas Fireplace - Napoleon ...
napoleonfireplaces.com/clean-glass-direct-vent-gas-fireplace/.
or go to this link might help you.
how to clean cloudy gas fireplace glass Google Search
Oct 30, 2017 | Dishwashers
Hitachi 55" plasma Director's Series
Replacing the front glass entails completely disassembling the entire TV. Your best bet is to look for a broken TV with a good front glass.
May 28, 2017 | Hitachi 55HDX62 55 in. Plasma HDTV
Is it possible to clean the inner side of the glass front screen from my panansonic TH42-PZ80
Anything is possible! It would be a lot of work because you have to totally disassemble the tv to get it broken down far enough to do that - and also make sure you dont break either of the glass when disassembling or reassembling.
thanks,
Michael
Apr 05, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Ceiling leaked into the plasma tv now has a black streak . can this be fixed
Hi my name is Eric,
I hope I can help you with your issue ,
Well you could take it apart and see, most plasmas have a glass front with a screen behind it. If you take the screen out you could clean the glass if thats where the black is. This job is about 2 hours on most plasmas.
If your TV is an LCD then there usually is no glass, tough the front and check. in that case you'd need a new screen
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 01, 2009 | Sony KDL-40S3000 40 in. LCD HDTV
Tried to wipe off a small spot w some furniture polish on a t-shirt and now it is a large spot maybe from some residue. How can I best clean it without messing anything up?
Um, sorry to say. you may have damaged the unit. Panasonic plasma televisions have a coating on the glass front to reduce infra red emissions and reduce reflections.The only thing you should clean them with is a damp cloth (water only).
go to the local electronic shop and get a special cloth for cleaning flat panel displays and try that. if it doesn't come off with that, then it will need the front safety glass replaced.
Sep 27, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
