KitchenAid KSRG25FK Side by Side Refrigerator
Problem for KitchenAid KSRG25FK Side by Side Refrigerator
Freezer wont defrost and refrigerator is to hot
By aimeemurphy on Jul 20, 2009
i just got a new refrigerator and the freezer wont defrost. This started at the very beginning. A couple of weeks later the refrigerator starting getting to warm and my food started spoiling. I've checked the temperature and it seems to be staying between 52-56 degrees.
Best Solution
posted on Jul 20, 2009
Very Helpful)
projdoc
Rank: Guru
Rating: 94%, 610 votes
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for KitchenAid KSRG25FK Side by
Questions and Unsolved Problems for KitchenAid KSRG25FK Side by
Do you recommend KitchenAid KSRG25FK Side by Side Refrigerator?
Answer
Answer
I have Whirlpool fefrigerator model GS5SHAXNL00, the maker used to work for a while and stop for a... (More)
Answer
I want to test run the compressor ,the starter is burned up copressor ohms out ok run capacator... (More)
Answer
there is a water line connector at bottom of fridge but don't know where it hooks up. Can you help?... (More)
Answer
This thing runs almost constantly but unless it has a separate compressor for the freezer and... (More)
Answer
There is a red light inside the freezer and it is flashing. It is not cold inside. The refrigerator... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid KSRG25FK Side by...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
