Question about Canon Office Equipment & Supplies
How can I clean the printhead of pixma ma800 - Canon Office Equipment & Supplies
    Top Expert:
  • Canon Master
  • 85,020 Answers
Cleaning the Print Heads from Your Computer
The print head cleaning function allows you to clear up clogged print head nozzle. Perform print head cleaning if printing is faint or a specific color fails to print, even though there is enough ink.
The procedure for cleaning the print head is as follows:
Cleaning
  1. Open the printer driver setup window
  2. Click Cleaning on the Maintenance tab
    When the Print Head Cleaning dialog box opens, select the ink group for which cleaning is to be performed.
    Click Initial Check Items to display the items you need to check before performing cleaning.
  3. Execute cleaning
    Make sure that the machine is on and then click Execute.
    Print head cleaning starts.
  4. Complete cleaning
    The Nozzle Check dialog box opens after the confirmation message.
  5. Check the results
    To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
    If cleaning the head once does not resolve the print head problem, clean it once more
Posted on Nov 30, 2016
SOURCE:
Cannon PIXMA MG500
Hi! try printhead nozzle alignment and head cleaning from maintenance tab in printing preferences. it will print a test page after cleaning printhead. Good luck!
Nov 30, 2012 | Canon PIXMA iP5300 InkJet Photo Printer
The orange light on Pixma ip4300 is flashing 5 times.
Hello, the error you describe is for a faulty print head. When the printer is on open the cartridge acces panel, remove all cartridges, remove the printhead and check the printer and printhead golden contacts. If they are dirty clean them with alcohool (make sure, when you clean the printers contacts, the printer cable is pluged off the power). If that dont help you will have to change your printhead (more than 100$).
Jul 09, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
How do i remove and clean the printhead from a canon pixma mp780?
Hi there. i understand that you want to clean the printhead of your canon pixma mp780, dont worry im here to help you out with this.
do this following steps in order for you to clean the printhead.If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Take Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary ok?
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
hope that this steps helped you a lot in cleaning the printhead of your printer.Good Luck!
May 30, 2011 | Office Equipment & Supplies
How to clean a printhead for canon pixma MP540 . i have used the deep clean but no help
Deep clean should clean the printhead, but it's an expensive way to do it, since a lot of ink is used.
Do you have lines of non printable areas? Maybe replacing the printhead will help.
May be out of ink in certain nozzles on the printhead.
Oct 19, 2010 | Canon Office Equipment & Supplies
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Turn off the printer, and unplug the power cord. Remove the cartridges, then the printhead unit, clean the printhead in look warm water GENTLY. Dry completely, clean the contacts with an eraser GENTLY. wipe contacts with tissue, then re-install back into the printer, add the cartridges, so an alignment and a clean, then print.
Jan 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Won't print text from microsoft word or anything like that, only prints pictures.
Perform a deep cleaning on the printhead:
1) power on the printer
2) access the menu button
3) scroll down to printhead cleaning
4) deep clean the printhead 3x
5) try printing again on Msword
Jan 02, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Aug 13, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printhead problems Canon PIXMA MP780
that definitly sounds like it needs to be replace, have you tried using the printhead cleaning utility?
Dec 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma ip3000inkjet printer
The printhead is clogged.
See the following guide:
Canon iP3000/4000/5000 Printhead Cleaning Guide
If it does not work, replace the printhead: Genuine Canon Print Heads
Nov 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Streaks on photos
Take out your ink cartridge and clean off the bottom of it with a damp cloth.
Jun 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
62 people viewed this question
Clive
Clive
old marine
old marine
