Question about Hitachi 53UDX10B 53" Rear Projection Television
Power will work for a while then turns off
  • Hitachi Master
  • 5,138 Answers
Resolder all poor connections and replace your STK ICs.There is also 7 resistors that should be replaced as well in the same circuit as STKs. Low ohm resistors 1.5, 2.7 3.9 ect.
Posted on Jul 20, 2009
Computer won't turn on.
There must be a problem with your power switch on your computer casing, or motherboard or power supply.
Detach your power supply and try this, to check if your power supply really works. If the auxiliary fan will turn, your power supply is good
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-0.jpg Testing your power supply and motherboard as seen on photo
25627818-lfqggqo5gl3n2v4xynrvsb5u-5-2.jpg If the cpu cooling fan and power supply did not turn the fan, but you have checked already the power supply that is working then you can conclude that your motherboard is need to be replace. But the power supply and motherboard and working, meaning to say your computer casing need to be replace or try fixing the contact of the switches attach to your casing.
Have a good day.
Apr 04, 2015 | Dell Studio Xps 9100 Desktop Computer
M8000
1) Check if the power cord is working properly.
2) If you can open the desktop check the power supply is working properly
the fan of power supply must turn on when you do this
3) if the power supply does not turn on the power supply is faulty.
40 If it turns on then there is problem with motherboard
May 17, 2014 | Computers & Internet
2000 tacoma flashers don't work but turn sig do work!
The hazard switch gets power from the horn fuse which is hot all the time, and from the turn signal fuse which is hot when the key switch is on. The turn signal switch gets power from the hazard switch and both use the same flasher.
So if the turn signals work but the hazard switch does not power the lights, and both fuses have power, I would say the problem is inside the hazard switch.
Feb 19, 2013 | Cars & Trucks
Just Plain stopped working
I'll assume you've already checked the obvious possibility that the outlet the computer is plugged into is not working.
Here's a diagram of the main power plug from the supply:
With a short wire (like a bent paperclip), short the green wire PS_ON to the ground pin on either side of it (in the same row, not directly across in the plug!!). The power supply should start up if it's working properly. If the supply doesn't come on, replace it. If it does, then you'll need to replace the main board.
That's the way electronic components usually fail. The initial surge when you turn something on causes a part that was ready to fail to go bad, the same way a light bulb usually burns out when you turn the light on, and not while it's already lit. So the computer was working fine, then the next time you turn it on....pffft!
Mar 30, 2009 | Ultra 500Watt ATX Power Supply with 2-80mm...
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Samsung syncmaster 753df power button no longer works
check in back side of monitor reattch power cable after clean dust from it.
also check with other power cable that your monitor turn on with other cable.
Mar 21, 2009 | Samsung SyncMaster 753DF Monitor
Dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Jan 09, 2009 | Dometic Rooftop RV Air Conditioner
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
Power
What you should try now is to try and power the laptop while it is ONLY on battery power. If that doesn't work, then pull the battery out and try and turn it on while ONLY on outlet power. If it works while only on battery power, you probably have a failed power adapter. If it only works on outlet power, you probably have a failed battery. If neither method gets different results, it's likely to be a failed component on the motherboard.
Jul 29, 2007 | Toshiba Tecra A3 Notebook
Hitachi 53UDX10B 53" Rear Projection Television Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
