How-to repair my Verbatim Store 'n' Go 8Gb USB stick? It bacame read-only and I can't format it.
SOURCE: How can I recover my Verbatim Store 'n' Go Red 4G memory stick?
Hi Karen
Follow the link bellow i have used this a couple of times and it seems to work well
http://www.filehippo.com/download_recuva/
Regard Alan (alstech)
SOURCE: Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Testimonial: "Spot on!.. I found your answer match my further investigation.. Thanks again for professional work and response..I will highly recommend site."
SOURCE: My laptop does not recognize my verbatim 8gb flash drive
go to Control Panel, then to System Mgr and then Devices. Check to see if all are marked with +s. You probably have a - in that area. Click on the minus and see what it says. You may need to add a driver or reinistall the flash drive.
SOURCE: my Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
SOURCE: can the drivers of the Verbatim 8GB Store N' Go
As far as I am able to tell, this device doesn't require drivers. It uses the Windows drivers, or those of your operating system There is V-key softare available from Verbatim's site, that's all.
Testimonial: "This solution is very helpful and I will try to get the V-Key from the Verbatim site, thanks very much"
