Find your settings icon, tap it, scroll through the menu until you find "Bluetooth", Bluetooth is just a wireless signal that allows devices to connect to eachother. You may have to put the device you are trying to pair with into search mode where it actively looks for a connection with near devices. Good luck!
SOURCE: passcode for hands free parrot bluetooth device
on the device
go to settings - pair with phone... - other phone
and the pin code will be dispayed on the screen
SOURCE: It says full memory on parrot 3200ls-colour when pairing
Send my an e-mail, I can explain you the solution for the error "memory full" [email protected]
SOURCE: Parrot 3200LS won't pair with anything
Try all com ports, eventually one should work, try deleting all paired devices from your parrot, it may be full.
SOURCE: how can i empty my memory of my parrot 3200ls.
You will have to go into the kit, settings -> paired device and then select on of the phone already paired and delete.
SOURCE: how do i pair my
The first
time that you switch on the 3200 LS-Color, you must pair your mobile phone
with the kit. 1.Enable the
Bluetooth mode on your phone. 2.On the
hands-free kit, scroll through the menus until you come to Settings Pair with
phone and select the relevant option for your phone. A 4-digit PIN code then
appears on screen. Memorize it. 3.Then from
mobile serach the 3200 LS-Color device Once the
search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on
your phone. 4.Select the
kit. Your phone prompts you to enter a code: key in the code shown on the
kit screen and confirm on your phone. 5.The kit's
screen displays "Pairing". 6.Once the
data has been exchanged, "pairing successful" appears on the 3200
LS-Color.
Thank You
The first
with the kit.
1.Enable the
2.On the
3.Then from
Once the
your phone.
4.Select the
5.The kit's
6.Once the
LS-Color.
Thank You
