Home | Sharper Image | Spion (AR001) | See two images at hig...
Sharper Image Spion
Problem for Sharper Image Spion (AR001)
See two images at higher power.
By dbarksdale1 on Jul 20, 2009
Works fair at the low power, but two images at higher power. Cannot use as is.
Best Solution
posted on Jul 31, 2009
Very Helpful)
Zeiss Man
Rank: Guru
Rating: 93%, 31 votes
Your binoculars are out of collimation. That means that the optical path needs to be aligned. Binoculars are designed so that the focus point of each barrel is the same over long and as short as possible distances. Binoculars that are properly aligned will still show a double image if you attempt to focus at something close that is too close for the models design. However this is not the same for long distances. The image at a long distance must not be doubled.
If they are under warranty and you haven't damaged them by dropping etc send them for repair to the manufacturer or ask the retailer where to send them.
If you are going to pay to have them fixed get a quote first. Binoculars that are of the zoom variety are not well thought of among binocular officionados as the quality of image degrades at higher magnification. For the price of repair you may be able to source a higher quality non zoom binocular.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sharper Image Spion
Questions and Unsolved Problems for Sharper Image Spion
Do you recommend Sharper Image Spion (AR001)?
Answer
Answer
I have PV series compact binoculars that the lense have gotten slightly out of synch. The images for... (More)
Answer
lost the battery cap
Answer
transmission fluid capacity for 2005 tundra
Answer
Need to identify fuse that controls power to trailer connector on 06 tundra crew cab
Answer
Driver does not work! can I download one?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharper Image Spion:
Top Binoculars Experts
Rank: Guru Guru
Solutions: 885
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Binoculars Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
