Question about Whirlpool AD25BBR 25 Pint Per Day Dehumidifier w/ AccuDry Sensing System & EZ-Empty Bucket Humidifier
When I plug the unit in it gives a puff of smoke and kicks my breaker
  • 4 Answers
Sounds like you have a pinched or bare wire inside the unit. If it has louvers for ventilation, I would try this experiment, but just once, and it needs to be at night. Reset the breaker, and get a small flashlight. Go to the unit and get it ready to plug in. Turn off the lights in the room and make sure it is really quiet, use the flashlight to get to the unit and the plug. Looking at the unit, turn off the flashlight and plug it in. You should listen for a crack or pop (the sound of the short) and watch inside the unit for a spark (the location of the short). If my hunch is correct, you will find the problem and be able to repair it. If not, then I would recommend calling out a tech or taking the unit to a repair depot. Good Luck.
Posted on Jul 20, 2009
Unit says, Call for Service. What does this mean?
hi Teri.
i think its telling you to call someone out to come and service it or to have a look at it.
Dec 06, 2017 | Honeywell Humidifiers
When I plug in my Vicks humidifier my breaker throws
then id not plug it in again , the breaker goes telling you there is a fault in the device , also could be too many items on that breaker , ive got an ole vaccum that will trip my breaker out if I run my radio and try to clean up at same time , but will not trip if I switch radio off b4 use .got to be such a bother that I stuck a post-it on vac that says "radio" just to remind me to switch it off b4 I clean up , saves me from running down three flights of stairs to reset it !!!
Dec 13, 2016 | Vicks Humidifiers
I live in the Caribbean where the voltage is 220/240 so I need to know what size transformer I need to use with a 5.8amp Vicks vaporizer
Hi, you would need one that's around 1400 watts (watts = volts x amps so 240 x 5.8 = 1392)
I hope that helps.
Jan 08, 2015 | Vicks Humidifiers
Aprilaire fan won't kick on
Is the air unit plugged in electrically?
Oct 18, 2013 | Humidifiers
When plugged in & turned on... It doesn't do anything... No lights at all.
Check the outlet that it's plugged into, to make sure that the outlet is still active and a circuit breaker in your home's breaker panel hasn't been tripped. If nothing else, plug the unit into another outlet, that's on a different circuit.
Apr 28, 2011 | Air-O-Swiss AOS 7135 Humidifier
I have an apprilaire 700. I pulled the plug on it because the water department had a main break. Since then the unit does not work. I connected the brown wires that come from the unit while the furnace...
If water main break you may have a little debris in the water line. There is a very small orifice in the solenoid and would not be hard to plug. Shut water off and pull line off humidifier and see if you can blow out line.
Jan 16, 2011 | Aprilaire 700 Humidifier
When I turn on the unit, it humms and the fan doesn't turn. Help.
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
Nov 19, 2010 | Bemis 697 400 Humidifier
Breaker trips each time i try to star the unit on cooling
it sounds like the compressor has shorted out the best way to find out is use a multi meter and text the terminals on the compressor to ground if the multi meter sounds off in the diode setting then the compressor has a dead short hope this helps good luck
Aug 04, 2009 | Humidifiers
Transformer
It sounds like a wiring problem. If you still have the instructions that came with the unit, look at the wiring diagram and make sure you have everything right. If you dont have the instructions, you can find them online. Be careful you dont zap yourself! When you're in there playing around with wires make sure you kill the power to the furnace at the breaker. Double check this with a voltage tester if you have one. Also, if you're not sure you may want to disconnect the unit until you can afford to have a qualified professional look at it or you may end up doing more harm than good.
Dec 07, 2008 | Aprilaire 550 Humidifier
Humidifiers Logo
70 people viewed this question
Top Whirlpool Humidifiers Experts
Paul Carew
Dennis
Are you a Whirlpool Humidifier Expert? Answer questions, earn points and help others
