Question about Philips 50PFP5332D 50 in. Plasma Television
Hi. I have a philips plasma (50PF7521D). How do i adjust the colours seperatley (red too high, green too low)? Thanks.
  • 10 Answers
You have to adjust the colors in the menu manually. It can be done but look at the manual online if you need help finding where in the tv menu the color adjustments are located. Best of luck and yes, you can adjust them manually and not use a preset scheme.
Posted on Jul 21, 2009
PSU on philips 50" plasma just clicks when powered up and TV does not show any lifr in audio or video. Green light responds to the remote..
Sounds like sustain board fault. Check and replace the damaged one. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 04, 2015 | Philips Televison & Video
My philips 50" plasma 50pf7521d/10
it sounds like the standby power is going out on your main power board. It could be the 1000uF capacitors or a few smaller ones. Check for swelling in the caps and if you see none I would suggest ordering a new power board it will run you about $200 give or take $50 depending on where you find it.
Jun 12, 2011 | Televison & Video
The green power light turns red then starts blinking ,tv wont turn on
Either the power supply or high voltage transformer is shot. You have either one or the other in your set. Most likely faulty high voltage transformer which commonly burn out quick nowadays. You can test it with a voltmeter .Also check for bad capacitors.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Philips 42PF9631D 42 in. Plasma Television
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
I have to much red in my picture
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant red picture tube, a bad red driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. This TV set most likely will run you about 200 to 400 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
My plasma picture looks green
You are proberbly using RGB leads, wich is red green blue, each colour runs through each cable, have a look at your cables maybe one is loose, or damaged. check on both ends, but the cables MAY NOT be red green and blue, but the terminals that the plug into will be.
Jul 05, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
NEC plasma television
hi jubbi, actually i'm not sure your problem you describe. So you can go to this link http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html see your plasma tv problem is it inside this guide?
Aug 31, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Philips 50PFP5332D 50 in. Plasma Television Logo
159 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
