Question about Toshiba Sattelite A105-S2071 Notebook
Blank screen I have a Toshiba A105, unit PSAA2U-049018 that we closed the unit when it was on and when we opened it up, we have a blank screen.
Bios password
Technically, it is easy to remove this model's BIOS password, but probably it is inappropriate to discuss it in this forum. I think you can discuss it with local computer tech in the city where you live.
Mar 01, 2014 | Toshiba Satellite A105-S2081...
Toshiba a105-s2081 turns off 1 sec and back on repeatedly
Laptop dirty inside?
Thermal Paste in-between Processor, and metal plate of Cooling Tube, dried up?
What about the Thermal Pad in-between the graphics chipset, and metal plate of Cooling Tube?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
USE an ESD wrist strap. Connect it's alligator clip to a good ground source.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 19, 2013 | Toshiba Satellite A105-S2081...
I reinstall my OS windows xp now i need help find the display driver
www.toshiba.com
type model number
Display driver :H D Graphics
Sep 25, 2011 | Toshiba Satellite A105-S2081...
Hi, I have a Toshiba Satellite A105-S4254 when I boot the laptop it goes to the windows xp screen, after that right before the starting up screen, it goes to a blank black screen with the mouse cursor, but...
try restoring this unit to an earlier time
in restore function is a calandar check which things were updated last time
go to start
all programs
accessories
system tools
restore
heres the restore function
Apr 18, 2010 | Toshiba Satellite A105-S4254 Notebook
My toshiba satllite A105-S4011 screen is not working.when i on it ,the screen comes and go.how do i repair it?
it could very well need a cable, or sometimes it is the lcd. when does it come and go? when the screen is opened or closed slightly
Oct 25, 2009 | Toshiba Satellite A105-S4011 Notebook
External monitor connection problem
The problem is with the laptop. The femal VGA port is slodered to the motherboard. Once the laptop's MB has been removed you'll most likely find the solder holding the VGA in place is most likely cracked/loose. The fix would be to remove the old solider & apply new.
I can't guide you through disemble, its complex. I can include a site to help you with this.
http://www.laptopka.com/2006/03/18/removing-laptop-motherboard/
If you find this all a little too involved it might be worth taking it to a pro.
At this link you can order A105 parts if needed.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,PSAA2U-01T018,Laptop,Parts.aspx
I hope this helps you kevinwaynewh!
Mike
Jan 29, 2009 | Toshiba VGA Board Graphic Card
Toshiba A105-S101 freezes at start up!
I would first attempt to reinstall the software from the install cd. Your Toshiba support page is recomending a new BIOS upgrade. See below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209144&rpn=PSAA2U&modelFilter=A105-S101&selCategory=3&selFamily=1073768663&selModel=1209144|PSAA2U
Dec 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba a105-s4344
In both cases it sounds like it could be a graphics card problem. You could try to find the latest driver updates for your graphics card by searching the internet for the most suitable driver & / or updates. (When software is automatically (Microsoft/Windows/etc) updated from the internet, it may be of versions that are no longer compatible to you Hardware drivers)
Overheating could also cause the problem if you have an older Laptop, with the latest software.
Mar 31, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Sattelite A105-S2071 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
