Question about Canon PowerShot SD600 Digital Camera
Lens stock out says to reset camera
  • 104 Answers
Re: lens stock out says to reset camera
Internal lens barrel has been damaged,so lens could not move therefore it gives lens error.
this problem due to damaged gears or barrel dislocations.
not by dust,it is repairable..
Posted on Mar 06, 2008
0 characters
3 Points
PD170 - NO POWER. Dead as doornail. AC or batts.. No surge/ or anything strange happened... was having issue of resetting itself everytime turned the cam on...but that stopped recently. Is there an...
some cause of this is when the battery goes empty it willl not return the zoom lens correctly that may stock up. so when you power it again the lens is not initialized. so the camera will off it again.
go to service center or qualified technician to repair it.
May 30, 2011 | Digital Cameras
My lens are stock up..whenever i start the power it only activates the power for a second.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
May 26, 2011 | Samsung Digital Cameras
Lens error.. lens is stock up
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
May 21, 2011 | Canon Digital Cameras
I drop my sanyo camera the lens is stock
If you look at the lens assembly, it is likely out of place. This is often the case with many 'point and shoot' cameras and in often cases the lens assembly needs to be replaced. Frequently however the lens assembly repair ends up costing more money than a new camera itself. You can attempt to contact precisioncamera (google it) or a local camera repair place and see what they would charge you to fix the lens assembly. But in my experience it normally cost more to repair one of those cameras than replace it.
Mar 02, 2011 | Digital Cameras
The lens can't open :( it tells that " turn it on again" :( somewhat look that it is stocked or jammed :(
Find some thin plastic that you can slip in around the edge of the lens and as you switch on try to move the plastic around to help the lens out. Sometimes a little grit or dirt is preventing the lens opening and that works. Also tap the base of the camera as the lens is trying to extend. If neither of those work you will need to dismantle it.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Lens stuck and making beeping sound
Hi,that is probly the mechanism of the lens gear system is stock whit a debrie or sand pieces you can try to blow some air
in the space arround the base of the lens avoid to apply any pressure on the lens,at the same time you blow the air press pwr on and off to make the lens gear to get free , if dont works/ you needs a technician to fix it.
that is all i say from here
hope that will help
Regards Alan.
Ps ;that is a common problem for this type of camera.....
Oct 22, 2010 | Samsung Digimax S500 Digital Camera
The lens keeps going in and out and says lens error
was it ever dropped or stock somewhere moist? above all, not good news. The message indicates that the lens housing has beendented or otherwise damaged, preventing the camera from functioning.Your camera will require professional repair.
Sep 11, 2009 | Nikon Coolpix S210 Digital Camera
Lens hood can't be removed from 18-105mmAF-S DX VR lens-stuck in
i don't want to preach.. but what's that hood diong there? but whatever the reason is i'll be helping you. simplest way is not to stop shooting therefore you won't face the same problem. glad to be of help.
Mar 15, 2009 | Nikon D60 Digital Camera
Lost lens cap
That should be the cap your looking for if not let me know. Please take a moment to rate my solution fixya if it helps.
Thank you,
Jan 04, 2009 | Canon PowerShot Pro1 Digital Camera
some Canon user forums have posted that you can GENTLY tap the lens with a softer object (wood preferred) and the lens will go back upon the next power up. I have not tried this, but they say it works, but you should be extremely careful.
Nov 27, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot SD600 Digital Camera Logo
77 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
