Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Door opening too far.
I'm not sure what model Frididaire dishwasher I have, but when the door is opened all the way, it is not parallel to the floor, but slopes down toward the floor slightly. This causes the bottom rack to roll out rapidly and I've had to catch it on a few occasions so that it doesn't fly out onto the floor. The maintenance man at my apartment complex told me that the door sloping is normal. Is there a fix for this problem or is it indeed normal and I'll have to learn to live with it?
  • 4 Answers
You need to adjust your door tention springs along the sides of the dishwasher. though they may need to be replaced altogether.
Posted on Jul 28, 2009
  • Jeffrey Genos
    Jeffrey Genos Mar 05, 2014
    how do you adjust these springs? I looked it up in the manuel but it didn't say anything about it
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Why does door open too far and is not horizontal to the floor when open?
Besides spring streaches out over time or one rope breaks. Their are like three spots to hook spring to get tension for door. I just replaces both ropes as one broke and hooked springs in middle hole. Takes more time to pull washer out then to replace the ropes
Oct 31, 2015 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher shutting off during cycle, seems the door is not closed tight enough. If I apply pressure to hold the door tighter it will continue the cycle.
sounds like fatigued or tweaked hinges. Take a good look at the door when it's open without the bottom rack pulled out. It should be parallel to the floor. If it is past paralell... check hinges. See if they can be adjusted.
Sep 23, 2012 | Furniture
The door on my Frigidaire dishwasher recently began opening too far. It slants toward the floor, a few degrees past level. Looking at it, however, nothing seems to be broken or missing. The springs are...
I have the same problem. The springs look intact. Maybe some stepped on the door when it was opened and it stretched the springs. I'm going to replace them and see what happens
Jan 14, 2011 | Dishwashers
Door closes to fast and sometimes re-opens by itself
A couple possibilities here. Make sure the door spring isn't broken. Your door is traveling too far in the down direction and when it hits the floor the safety sensor reverses it to the open position. The down limit adjustment is on the side of the motor unit.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens all the way down does not stop
The door is very simple as you already know. The only adjustment is with the springs. If they are in place and the door still drops too low (and probably very quickly stopping with a jar) then the springs are over stretched. This does happen over time.
Take one off and go to a hardware store. Look for ones slightly shorter to replace. Springs are springs so if they fit you are good to go. Or go to a parts shop and purchase replacement parts.
Please rate if this helps you.
Mar 09, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
GARAGE DOOR CLOSES TO THE FLOOR AND OPENS ALL THE
If the garage door is hitting the floor and reversing to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover. A little tweaking should get it just right.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door wont close all the way
NOT SURE WHAT UNIT YOU HAVE .
ALL OPENERS HAVE AN ADJUSTMENT TO TELL IT HOW FAR TO GO UP AND HOW FAR TO GO DOWN. LOOK ON THE SIDE OR UNDER A LIGHT COVER.IT HAS TO BE THERE SOMEWHERE
Nov 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Feb 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
509 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
