Spyder3Pro monitor calibration has just asked ICC Version either 2.0 or 4.0 for RGB Slider option for the Dell 24" Wide Screen Ultrasharp Widescreen Flat Panel
  • 2 more comments
  • wayne428 Jul 20, 2009
    OK will do that.
    Does the Dell 24" Wide Screen Ultrasharp Widescreen Flat Panel have all these controls. This is a critical part of set up. Or just Brightness and Contrast.
    Identifying Controls:
    1. Brightness
    2. Contrast
    3. Backlight
    Manuals are not clear on this question. I know that most Laptops only have 'Backlight'.
    I found from Spyder3Pro support that the RGB Slider is only for CRT monitors.
    Does it have a Backlight function as well.
    Thanks very helpful
  • 13,433 Answers
Actually I want you to go back to the RGB slider and UNCHECK it, leave them all unchecked and click Next.
Posted on Jul 20, 2009
  • 1 more comment
  • Ekse Jul 20, 2009
    These are the RGB sliders on your display
    I do not know which version that is, But for the time being you should be able to adjust the display without selecting any of the 3 options and just click next.
    I will look into the ICC version and get back to you.
  • Ekse Jul 20, 2009
    Your monitor does have Brightness and contrast settings.
  • Ekse Jul 20, 2009
    No It doesn't have a backlight that you can adjust as laptops would have.
    but you can adjust the other two settings.
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My dell monitor model #1800fp diplay is elongated for all pictures I display on the screen. How do I correct this
should be on the menu on front of monitor ,,with options to change that,,and check control panel on cpu,,make sure its set rght,,for widescreen or regular
Nov 03, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I am the Graphic Artist and Printer for a public library. We have a logo that has the Pantone color PMS 375 green in it. I mix my own inks and have no problem reproducing the color properly on a printing...
Laser printers, although they have a larger color gamut than a CMYK offset press, still will not be able to reproduce a majority of Pantone special colors.
Professional inkjet printers, especially those using more than 4 inks, are far better at this - the ink pigments are more color-pure and concentrated than those in laser toners.
Remember, that Windows print drivers work in RGB, and use ICC profiles to convert color data to CMYK components for printer. If you have a CMYK file, and look at it on your monitor, it's converted (using monitor ICC profile) to monitor's RGB colorspace, and then back to CMYK with the printer ICC profile when printed. Converted twice with ICC, which always introduces distortions...
If you have a properly calibrated monitor, and a good printer profile installed, you have better chances of reproducing screen colors on the printer, especially if you work in RGB.
As a simple, but laborious solution, I would suggest preparing "swatch sheets" yourself using some graphics software. Preferrably in RGB, not CMYK. A series of gradients with the green component going from, say, half way to maximum, and other components in various combinations, like R0 B0, R10 B0, R20 B0,... then R0 B10, R10 B10, R20 B10... and so on. Print those, and try to find a spot in the gradients that is the closest to your color sample, and then make swatches with smaller increments around that color to find the best RGB combination.
Good luck :)
Nov 13, 2009 | HP Color LaserJet 5550hdn Printer
Half of the screen has a blue tint.
better change it. if you are in North america its useless to repair. you can buy a new one for this price. one more option tap the screen 4--5 times from the top. good luck.
Oct 22, 2009 | Dell 2405FPW UltraSharp 2405FPW 24'' LCD...
Dell 24'' Ultrasharp went blank
I suspect the invertor supplying power to the Xenon backlight tubes has failed.
This can be reapired but may not be cost effective.
Ask for a quote from your local computer specialist but keep in mind the cost of a new monitor.
Mar 18, 2009 | Dell Computers & Internet
Rotating screen view
To change the orientation of the display you need to change settings on the video card properties. Just physically changing the orientation of the LCD will not change the display on it. (Generic options to follow are : Right click on desktop > click properties > click tab settings > click advanced > click on tab of video card name > you should find the rotation option on this window)
NOTE : if these options are not available, high probability that your video card does not support orientation / rotation of display.
Oct 27, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
