Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
My quiet II dishwasher is leaking; I pulled it out and I see water dripping off the the housing of the motor underneath. The floor would indicate that it has been leaking for years...
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
nmds673
Posted on Sep 29, 2010
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
Water leaking under the dishwasher
I have Kitchenaid model number (KUDE70FVSS2) and thought it was great (so quiet) until recently when I had to remove it for unrelated reason. That's when I noticed leaking (slow drip) when running. Laying on back (to prevent water going everywhere) isolated problem to the motor (diverter motor) and with a little internet research discovered that the factory had installed the washer (between the motor and the sump) upside down! Washer has deep groove which should face downward so that it covers part of the motor housing and seals completely. Well as result washer had been leaking (slowly) for a while, and on top of floor damage, motor connectors corroded into nothing. Motor actually seems fine and (be warned) replacing wouldn't fix the problem. Now trying to figure out how to reconnect wiring to motor without having to buy whole new wiring assembly. While motor replacement is fairly easy (two screws and two wire connectors), replacing entire wiring assembly involves door disassembly, lots of connectors and it's twice the price of the motor. Grrrr so mad at manufacturer now since this seems like intentional obsolesce.
efac4cf2-0542-4eb2-bb73-eadaf192d266.png e9aafc3a-da97-45ca-83e3-bd424971ad46.png 6deca94c-b9a9-4f73-89b3-da843200872c.png 4bcdf922-94a3-4853-bca5-e89d20798320.png
May 09, 2011 | KitchenAid KUDE70FVSS Builtin Dishwasher
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Maytag MDBH950AWB Leaking
Leaking Dishwasher
heatman101
zgwerty
Feb 23, 2009 | Maytag 24 in. MDBH950AW Built-in...
GE GSD222oz dishwahser
You need new pump seal. Will need to pull dishwasher and pull motor/pump
Jun 16, 2007 | GE 24 in. GSD2220Z Built-in Dishwasher
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
132 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
