I have an old Scotts 2 in 1 mulch side discgharge power propelled mower with a 6.5 hp Intake Edge OHV briggs and staratton engine. The starter rope broke.
I took the plastic cover off the top and then there was a metal piece over where the rope should go. There are 3 or 4 bolts that have a round place, not a phillips or flat head screw. How do you get those off or what do I need to do next to replace the starter rope?
Could you give me step by step instructions on how to replace the starter rope. I would greatly appreciate it.
thanks.
SOURCE: Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
SOURCE: 5 hp briggs and stratton mower is hard starting
Most times the briggs engines start hard when hot because the exhaust valve is leaking at the seat.If you hear a hissing noise from the muffler when you are trying to start instead of a good crisp pop it that is a good indication the valve is burnt.To be sure you would have to have a compression or leak down test done on engine.A valve job is not an easy job if you don't have the right tools.
SOURCE: Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
SOURCE: snapper riding lawn mower won't start
my snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
