Question about PfaFF Sewing Machines
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my foot isn't on the pedal.
  • 55 Answers
Is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Posted on Jul 27, 2009
What is smart pedal foot control for Bernina? I have a Patchwork Edition 140 and needle stop down should be controlled by pedal according to shop. I don't understand.
The foot control you are talking about will activate the needle down function on your machine. You need to press down on your heel on the foot control. This was the precursor to the automatic needle up/down option that is found on newer sewing machines that will automatically stop with the needle in the down position.
Mar 12, 2017 | Sewing Machines
How do you change the speed on a typical sewing machine2603 ?
most sewing machines are controlled by a foot peddle the harder you press the faster it goes but if this one is electronic it should have another method of slowing it down
Feb 23, 2017 | Sewing Machines
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
Why does my machine stop after 8-10 seconds
I need more information. Which model? What appear on screen?
Jul 23, 2014 | Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Bernina Nova 900 air-pressure foot pedal going really fast all of a sudden
the foot pedal would have to be check at a sewing machine shop & they
could tell you more about weather it would be easy to fix or not
Apr 21, 2012 | Sewing Machines
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
May 03, 2011 | Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Sewing Machines Logo
345 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
