Question about HP Hewlett Packard Compaq D51S Intel Desktop PC - Intel Pentium 4 1.7GHz, 256MB RAM, 20GB HDD, CD-ROM, Flop
Screen resolution vga problems
    Sergeant:
  • 183 Answers
Need more clarifications.
Posted on Jul 20, 2009
Sony vpl dx 100. Why does it indicate frequency out of range when I connect my VGA cable to the the port?
Sony VPL DX 100 is a native XGA projector [1024x768]
so if u connect to a PC that has higher resolution than XGA , it will not be able to project and will show u out of range .
you will need to reduce the screen resolution in your resolution settings to XGA and the problem will be solved.
On a Laptop however, the graphics card should automatically identify the native resolution of the projector and adjust the screen resolution that is being sent from the graphics adapter.
you can also repalce the VGA cable and check if the problem gets solved as a broken pin or cable internally can also result in a similar problem!
Jun 05, 2015 | Sony Office Equipment & Supplies
Tip
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
on Aug 23, 2010 | Televison & Video
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
VGA: signal out of range on Dell1800FP. I see this type of card MSI PM8M3-V (7211010VPM8M3V) Motherboard installed. I know nothing, but would connect on Vga a Dell1800FP. Message : signal out of range
You need to lower your screen resolution. Right click desktop > Properties. Lower Screen Resolution to 800x600. You mave to do this in Safe Mode by pressing F8 during boot.
Sep 30, 2012 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
How do i increase the screen resolutions for the lg we-32Q10IP
I am fairly sure in VGA it is a fixed resolution---give LG a call with the model number and see how smart their customer service people are.
May 24, 2012 | LG Televison & Video
I am using windows XP SP3 and got a new 19" VisonQuest monitor but can't set the resolution.
Depending on your motherboard (or VGA card if independed) the maximum resolution may be lower than the requested by the monitor. The only solution for this is to add (or change) the VGA card with a newer one that can support the screen resolution (check the VGA's specifications). Another one solution is to use the screen at the maximum resolution that your VGA can handle. This is the easiest and cheapest solution but your on screen image quality will be reduced.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Computers & Internet
My computer turns on but the screen remains black. What should I do?
The problem can be solved by these steps
1) Check the Video connector properly connected to PC
2) Monitor power supply cable fault
3) The VGA card is not working properly
4) The screen resolution is set to higher than the monitor supported resolution limit
The Best way to solve it replace monitor and see it is working properly
In case the monitor still stay blank you should check the VGA card
Try to start cmos setup and see whether the monitor still remains blank then it's VGA problem
Feb 07, 2011 | Compaq Computers & Internet
Vga
Video Graphics Array (VGA) refers specifically to the display hardware first introduced with the IBM PS/2 line of computers in 1987,[1] but through its widespread adoption has also come to mean either an analog computer display standard, the 15-pin D-subminiature VGA connector or the 640×480 resolution itself. While this resolution was superseded in the personal computer market in the 1990's, it is becoming a popular resolution on mobile devices.[2]
VGA was the last graphical standard introduced by IBM that the majority of PC clone manufacturers conformed to, making it today (as of 2010[update]) the lowest common denominator that all PC graphics hardware supports, before a device-specific driver is loaded into the computer.[citation needed] For example, the MS-Windows splash screen appears while the machine is still operating in VGA mode, which is the reason that this screen always appears in reduced resolution and color depth.
VGA was officially superseded by IBM's XGA standard, but in reality it was superseded by numerous slightly different extensions to VGA made by clone manufacturers that came to be known collectively as "Super VGA".
Apr 14, 2010 | Foxconn P9657AA-8KS2H Motherboard
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Jul 21, 2008 | Envision EN-7100e 17" Flat Panel LCD...
LCD monitor screen blue
Either the VGA card or the monitor can not display the resolution correctly, so you need to get it back to where it was, this solution is for Windows users (not sure about other OSs), reboot your system and and get in the options start-up screen by pressing F8 at boot, choose safe-mode with VGA, if you see your desktop normally here then it's definately the screen resolution, set it back to a lower resolution (try 1024X768 and go downwards until it works fine), restart your system normally and you should be able to test new resolutions again, if it won't work using VGA mode then you might need to uninstall your VGA card but make sure that you have the correct driver for it before uninstalling, also please disable any onboard graphics card if you have one. I hope this would solve your problem, please feel free to ask if you any further questions regarding this matter. Thanks
Aug 16, 2006 | ViewSonic VA712 17" LCD Monitor
HP Hewlett Packard Compaq D51S Intel Desktop PC  - Intel Pentium 4 1.7GHz, 256MB RAM, 20GB HDD, CD-ROM, Flop  Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
