Question about Dell Dimension 3000 PC Desktop
When i want to use my cd rom to download a program it telling me to insert disk but the is alredy intge cd rom tray and its closed
  • Lrobby14 May 11, 2010
    I have dealt with this problem before on this exact model I need to know when you put the disk into the drive dose it make a clicking noise
    Problem Solver:
  • 11 Answers
First check if another CD is read by your drive, if so then it may be a problem with the CD you are using for the program. THe "autorun" file may be corrupted/damaged, run the "Setup" file manually by accessing the drive contents directly and it should be OK
Posted on Jul 27, 2009
  • 416 Answers
You lens might be dirty. try using a cleaner **** to clean the head
Posted on Jul 20, 2009
Dvd/cd rom not working
The drive may have failed. It can't read the disk.
Jan 16, 2014 | Computers & Internet
Changed hardrive now says no bootable device insert boot disk. dont have boot disk
Turn on the PC.
Supply the CD-ROM / DVD holding your preferred operating system - Windows, Linux, etc., into the CD / DVD tray and close the tray.
Wait up to 30 seconds for the CD / DVD drive to stop spinning
Turn the PC off.
Wait 15 seconds.
Turn the PC on.
Let the PC boot from the CD-ROM automatically / instruct the PC to boot from the disk in the CD / DVD drive.
Supply information as prompted.
If you do not have a CDROM/DVD, you will need to contact the PC manufacturer to obtain a start up disc & driver disk as needed. Explain to the support person that the old drive failed and a new one has been installed. No disk images were retrievable from the old hard drive. This should tell the person that you need everything to get this machine working as factory fresh once again.
You could purchase / download a different Operating System too - but this will likely cost much more than obtaining disks from the PC manufacturer.
Mar 28, 2013 | E-Machines Computers & Internet
Disk drive will not open
make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don't forget to vote
Feb 21, 2011 | E-Machines emachines (emachinees) CD-ROM...
How do i install the very small cd for my webcam 1H-3W00DB with only a large CD-ROM drive? is there free software anywhere on line i can inall instead? thank you. teri r.
Open the tray on your CD-ROM device.
Look closely -- this is a circular depression in the center of the tray,
which is _exactly_ designed to hold a mini-size CD-disk.
Or, if your computer is a "slot-loading" device, i.e., there is no slide-out tray, there is just a slot into which you insert the CD, like putting a coin into a parking-meter, then you need an alternate approach:
* find a friend with a CD-ROM device _with_ that tray.
* copy all the files from the CD-disk onto a USB memory-stick.
* move the memory-stick back to your computer.
* install from the files on the memory-stick.
Jan 23, 2011 | Apple Computers & Internet
.how to insert a disk in a computer laptop. I have
there will be a rectangle shaped cutting most often in the right side of your computer.then inside this cutting there will be another small minute cutting press it.insert the cd close
Sep 17, 2010 | Dell Studio 17 Laptop
My CD tray closes before I insert disk
check the micro switches on the cd mechanism. these can go wrong sometimes. it's obviously not sending a message to the micro chip that the tray is open therefor it will close again automatically.
hope this helps?
May 10, 2010 | Arcam Alpha 7SE
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
CLOSE THE INNER COVER
I should have added that the extra plastic insert thing that comes with the CD holder is used when you want to print on the smaller 8cm disks.
Dec 01, 2008 | Canon MP610 Photo All-In-One Printer
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Dell Dimension 3000 PC Desktop Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
