Question about Toshiba Satellite A135-S2276 Notebook
Keeps freezing when i'm using the machine it just freezes as in nothing works the mouse nothing even ctrl+alt+del doesn't work and i mostly have to start the machine without the power cable
  • NinaE May 11, 2010
    Works OK on battery use, only ??? When you use the power cable, it doesn't boot or does it freeze after boot ???
    Problem Solver:
  • 9 Answers
Starting the machine without a power cable isnt bad, especially since its a laptop and is made to run on battery power. as for the freezing, if it was dropped alot then something could have come loose meaning it mite not be covered under warrenty. i would just try to get it fixed at the place it was purchased at.
Posted on Jul 20, 2009
  • jab215 Jul 20, 2009
    starting the machine without a power cable isnt bad, especially since its a laptop and is made to run on battery power. as for the freezing, if it was dropped alot then something could have come loose meaning it mite not be covered under warrenty. i would just try to get it fixed at the place it was purchased at.
My mouse keep freezing up for periods of time and i have a restore cd that don/t do anything when i put it in
I wouldn't use restore cd
I would:
Press CNTRL + ALT + DEL, when the mouse freezes
Then i would look in the task manager and sort the columns by CPU % usage
See if a program is taking up all your CPU
Post back here the name of the program
You can then remove or fix the program casuing your system to slow
Apr 05, 2011 | E-Machines eMachines Desktop PC
I have a 4 year old Toshiba laptop running XP sp3. When I try to boot it up, it freezes at the blue "Welcome" screen and I have to turn it off by holding the power button. The keyboard works (mouse will...
Hi Good day!! there's a tricky way of your problem in the welcome screen try to press ctrl alt del at the same time. NOTE don't Enter it!!! after you press ctrl alt del press esc button see if it work i hope it works...
Oct 09, 2010 | Computers & Internet
My computer keeps freezing . How do you reboot a computer ? I am hoping if I do that it will quit freezing up when I am trying to play farmville on facebook.
Alt+Ctrl+Del but it sounds like there's something more wrong. Go into Control Panel>Add/Remove Programs and see what's there. Remove some of the rubbish and see if it helps.
Jan 30, 2010 | Computers & Internet
My asus eee pc series keeps freezing and nothing
most likely you have contracted a virus and need to reinstall windows. the only other possibility is a major hardware issue
Dec 28, 2009 | ASUS B50A-A1 P8400 Notebook
When we boot up the laptop freezes. You can't
try booting up holding f8 key and go to last good startup
Dec 12, 2009 | Acer Aspire 3000 Notebook
Mouse freezes --have to ctrl alt and del to sort it all time
check the usb port and chech the laser under the mouse that it might not attached any scotch tape ... and even dont work why dont u buy a new mouse
Nov 26, 2009 | Labtec 9675260403 Keyboard
My Desktop Hp Pavilion Elite m9250f goes in deep freeze
Do this it will surely resolve your issue :
1. Start > Search > Type" %temp% " > click > Temp(on the top) > Select all(use " Cntrl " + " A ") > Press " Shift " + " Delete " > Click " Yes " to the prompt.
2. Start > Search > Type" prefetch " > click " Prefetch "(on the top) > Select all(use " Cntrl " + " A ") > Press " Shift " + " Delete " > Click " Yes " to the prompt. 3. Start > Search > Type " disk " > Click " Disk Clean up " and just follow the all screen ionstruction.
This all above removes the unwanted, dump files files from the computer... which are not required by your computer. Alos scan for viruese on the computer.... visit malwarebytes.org or search on google for the same
Aug 01, 2009 | HP Pavilion Elite M9180F Desktop PC
Why does my curor freeze up?
First I would replace the batteries. I had the same problem a couple of years ago. The solution for me was getting rid of McAfee AV. To check if it is your problem, use CTL-ALT DEL to turn McAfee off and see if that gets rid of your mouse freeze ups.
May 24, 2009 | Dell Dimension 3100 PC Desktop
Ctrl + Alt+Del
Hi
is it a usb keyboard or a ps2(round connector) keyboard? the problem is most likely that due to the computer not having started up properly the keyboard is not properly configured / installed by windows.
to get rid of this problem, you need the old type of keyboard, turn off the computer, and plug in a keyboard to the ps2 connector.
green one is for the mouse, the other is for the keyboard, plug in a keyboard, then turn the computer on, you should be able to press CTRL+ALT +DEL now and ones you sign in to the computer it should install the usb keyboard and it should work from now on, just make sure the keyboard is not disconnected or port changed when the power is off from the computer that cause the configuration loss.
May 21, 2009 | Microsoft Windows XP Professional for PC
Acer 3000 Loads properly then the mouse and keys freeze
Goto Start>Run and type msconfig then press enter..In that window goto startup tab & disable the programs you dont required to be loaded at startup...
Nov 29, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
170 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
