Question about Braun Flex XP II 5790 Electric Shaver
Device will not charge...
I have had the shaver for a month, and now it will not charge. The unit is plugged in, I see the light inside the cleaner area, but the shaver will not charge.
  • gryen Nov 26, 2007
    My remington ms5500 will not take a charge. Not sure what to do.
  • grafikman Oct 06, 2008
    I had 2 units with the same recharging problem. I sent the first back and the same thing happened with the replacement. I was using an old shaver while deciding when to send the replacement back to Braun, and I gave it one last chance after letting it sit for a month -and it actually charged. So I deduced that if you let it totally discharge it will have the recharge problem till some undetermined timing event in the electronics happens. But this last week I was shaving and heard the charge start to die, so I tried to turn it off -but it wouldn't let me! It totally discharged while I was frantically pressing the power button and now I can't charge it again. This shaver is a poorly engineered malfunctioning piece of ****.
Just take it back to the store where it was purchased and they will trade it for a "New" (Not broken) one. It's the holiday season and you have a week or two, on returns. There is a two year warranty on the product ( Braun 5790 ), if you want to go that route. You can contact the company @ 1-800-BRAUN-11, the person, "I" spoke with, was very nice and didn't act like I was a problem and she didn't try to just blow me off.
Good Luck-
Posted on Dec 27, 2007
Power cord is not charging
Most likely, the batteries are dead and need replaced. You need two batteries and they can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
For installation videos, see links below
http://www.youtube.com/watch?v=D6jRpCnB8T4
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Dec 31, 2013 | Braun 8585 Electric Shaver
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Unable to charge the shaver. The charging unit is plugged in, but it doesn't seem to be able to charge the shaver.
The cleaning base is the problem. It probably got wet inside and the circuitry is damaged. This is almost always why these go bad. You dont have to replace it to use your shaver as you now know that you can charge the shaver directly from the cord.
If you want the convenience of the cleaning station, you will need to replace it. You can find a new one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-clean-charge-base-p-116.html
Feb 16, 2010 | Braun 360° Complete 8985 Electric Shaver
Was on travel in Australia and battery charged fine once and then the second time I tried to charge the battery it would not charge. Unit is dead, no lights come on. In Australia I used a good...
hello,
try the charger on another similar product to know if its still working, if it charges properly then the fault is not from the charger, probably the power pack has a fault. replace the charger if it is the problem but if not try to fix the shaver.
Jan 03, 2010 | Braun Syncro 7526 Electric Shaver
Panasonic 8077 cleaner stopped working
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} My model is almost the same as your model ...
Problem: Model ES7037
CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg
12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Comments:
YouTube pasted below:
http://www.youtube.com/watch?v=9b7lf5hqjag
Use that link to disassemble and clean the switch then put it back together.
All newer Panasonic Wet/Dry Shavers are probably the same.
Good Luck!
Jun 08, 2009 | Panasonic ES 8077S Electric Shaver
Braun won't charge.
I took the base apart and pressed the contacts out so that they can contact the shaver points easier, now it works like new. Turn the base upside down, press in the two clips and pull the inner portion out of the shell. You can now access the two charging contacts and press them or bend them so that they protrude out further. Make sure you unplug the unit and take out the cleaner cartridge before you flip it upside down too.
Mar 27, 2009 | Braun 360° Complete 8985 Electric Shaver
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Braun Shaver 360 Complete #8985
the 110 plugin goes into a circuit which changes AC to DC for charging the internal NiCad batteries. If there is NO charge whatsoever in the batteries, the shaver will not work. If you have any electronics background a simple test with a VOM will determine if the bridge rectifier is putting out any DC.[you must disassemble the shaver] If you have no experience on circuits take it to a repair location.
Sep 10, 2007 | Braun 360° Complete 8985 Electric Shaver
Wont turn on
Make sure the lock button is not in the lock position.
Aug 25, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun Flex XP II 5790 Electric Shaver Logo
375 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
