Error Condition
Indicator
Beeps
Error Code
Possible Solution
Paper Feed / Delivery
Orange
Remove any paper jammed
Paper Jam
Orange
Ink Out
Orange
Add Ink
BJ Cartridge Misinstalled
Orange
5
Re-install cartridge or replace it
NO BJ Cartridge
Orange
6
BJ Cartridge Error
Orange
7
Waste Full warning
Orange
8
Waste is almost full , needs service very soon
Service ErrorsBlinksBeepsError CodePossible Solution
ROM Error
1 x Orange
10
6100
Try unplugging Printer
RAM Error
2 x Orange
10
6300
EEPROM
3 x Orange
10
6800
Home Position
4 x Orange
10
5100
Temperature Sensor
5 x Orange
10
5400
Waste Full
6 x Orange
10
5B00
Needs Service
Cartridge OverHeat
7 x Orange
10
5200
Replace the BJ Cartridge(Printhead)
Cartridge OverHeat
8 x Orange
10
5200
Cartridge Displaced
9 x Orange
10
5200
Replace the BJ Cartridge(Printhead) or reinstall
Cartridge Displaced
10 x Orange
10
5200
Cartridge Displaced
11 x Orange
10
5200
Other Hardware error
12 x Orange
10
6500
None
None
5910
Needs Service
None
None
5C00
Needs Service
The Power Light Flashes Orange - Error Codes
When
an error occurs, the power light flashes orange. The number of orange
flashes followed by a long green flash indicates the cause of the
problem. Two orange flashes:Out of paper, paper jam, or paper feed error
If
no paper is loaded in the auto sheet feeder, or if the paper is not
loaded correctly, set the paper correctly and press the Resume button
on the printer to continue printing. Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly
Remove
and reseat the cartridge correctly. Make sure the orange protective cap
and tape have been removed. Make sure the blue locking lever is locked
down securely. Six orange flashes: BJ cartridge (printhead) is not installed
Remove
down securely. Seven orange flashes: BJ cartridge (printhead) is defective
Remove
the BJ cartridge and check that the contacts on the cartridge and
cartridge holder are clean. Make sure the orange protective cap and
tape have been removed and reinstall the cartridge. If the error occurs
again after you resume operation, you may need to replace the BJ
cartridge. Eight orange flashes: Waste ink absorber almost full
The
printer has a built-in waste ink absorber to hold the ink that is
consumed during print head cleaning. This error indicates that the
waste ink absorber is nearly full. Press the Resume button to skip the
error so you can continue printing. The POWER light flashes orange and green alternately: Service error
A
service error means the printer requires the attention of a qualified
technician. Count the number of flashes. (You may be asked this
information.)
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see?
At any rate here is the code:
Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician.
If you have any more questions let us know otherwise please don't forget to rate this post.
