Question about HP PSC 1410 All-In-One InkJet Printer
How can I get a clearer print? Everytime I print
How can I get a clearer print? Everytime I print a picture, they have lines through them. It looks like the color would be fading, but I just put a new color cartridge just in case, so I know that's not the problem.
  • 24 Answers
Beleive it or not, sometimes a new cartridge comes with the ink clogged too, put both color cartridges over a wet towel with windows cleaner by 5 minutes, then clean both with a dry towel, try to print, if the quality print stay bad, you have to suspect the printer cartridge contacts, check if are clean (if you have to clean it, do that with the printer off), if the fail continues try to use the manufacturer warranty
Posted on Jul 20, 2009
    President:
  • 3,278 Answers
As long as you removed the tab, first, I suspect that your new cartridge is faulty, since replacement does not solve the problem . A fading picture is an indication that your printer is out of ink.
  • NinaE Jul 20, 2009
    Hey, Giovarodrigu ... Good suggestion with the window cleaner !!!
What is the problem My samsung LCD TV picture went out and displays a grayish white background?
Hi
take a look in the picture line in menu.
open Samsung MagicAngle put it on off. My background became much clearer when I put it off
Jan 06, 2016 | Samsung LN-S3251D 32 in. LCD HDTV
Will it upscale any device that is connected directly into the system
Hi Craig
You don't provide the specifics of your system, but the general answer is 'probably not'. At least from the standpoint of doing more than spreading a down-rev signal across more screen lines or pixels. There are dedicated video processor units that are specifically made to interpolate video frames and break them into plausible upscaled pictures, say changing 720P to look like HD, or upscaling HD to look like 4KHD. It's all algorithm though, there is no more information content in the new picture than in the old one, so, likely as not, you can end up with a picture that looks pretty much like the old one, perhaps with clearer-looking edges from the hardware/software finding an edge and spreading it across more lines.
If you're running an old VCR with VGA output into the system, it will likely show you a picture taking the whole screen up, but it won't look any better than it did on a TV 10 years ago.
Cheers
D
Dec 09, 2015 | Audio Players & Recorders
How to change the tranny lines on my 1996 blazer from the tranny
There are small wire clips in the fittings recessed in the grooves. Remove the clips and the line will pull out. There are o-rings in the fittings for sealing the lines. If you need a clearer picture of how they work, go to a parts place and they will show you a fitting off the shelf to look at. Reassembly is easy. Just reinstall the clip first, and push the line into the fitting till it clicks.
Sep 25, 2014 | 1996 Chevrolet Blazer
Printing lines on the photo using bulk ink
Good Day!
Please follow the instructions:
1. open a blank document (word,excel,) 2. control P 3. under printer properties hit on maintenance tab. 4. then hot on head cleaning. once done, "print check pattern" 5. please continue doing this until the print out goes clearer. 6. then, try to print. i hope this helps.
Jul 20, 2011 | Epson Stylus R290 InkJet Printer
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My printer is printing pictures with lines on them
When you get lines that usually means a memory problem. Well it usually means the picture is too big for the memory. Try setting the quality down a few notches and see if the picture improves.
sometimes the problem is on the PC end and it is doing to much. Shut down or turn off everything you can before printing.
If you have a really old slow computer it can be a combination of cpu and ram on the pc.
Usuallu turning down the quality fixes this everytime. The advertising is a bit decpetive as you think you can print picture quality on a full size page but in fact it only has enough ram to do it properlly on a much smaller size.
Aug 21, 2009 | Brother Office Equipment & Supplies
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
Shaded line on back of prints
I would suggest the transfer roller could be causing this problem
Mar 25, 2009 | Canon ImageRUNNER 1670F Copier
I have a solid yellow line down the centre of my picture
I have a Microsoft webcam and was having the same problems as the others using Logitech. I reinstalled the Skype programe again and my picture is clearer than ever. No Yellow line anymore.
Dec 13, 2008 | Logitech QuickCam Pro 5000 Webcam
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
HP PSC 1410 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
