Question about Bialetti 8853 Espresso Machine
Bialetti will not make coffee
I have a Bialetti 8853 Espresso Machine and when the seal wear out I replace it w/ a new one. However, each time over the years it takes me forever to convince the little coffee machine to make espresso. It is like the seal is not working and it has to swell or something in order to work. Any thoughts?
  • Anonymous Mar 11, 2008
    I have the same problem. Replaced the rubber ring and now the coffee (same grind as before) does bubble up. Frustrating.
  • Osiol Mar 21, 2009
    It worked with a dodgy seal that had started to decay. I replaced the seal and the filter and now the water just boils in the base and nothing comes through.
    Sergeant:
  • Bialetti Expert
  • 223 Answers
I would check the grind size you are using. Maybe it is ground too thin and the pressure cannot push through.
Also, remove screen and washer and make sure passage to the top is clear.
Shop Bialetti's Soon on:
www.CeriniCoffee.com
Posted on Nov 20, 2007
How can I clean the melted rubber seal from a Bialetti Top Espresso Machine?
I scraped off as much melted rubber as possible - using my thumb nail - then used a product called Goo Gone to melt the remaining rubber. I put Goo Gone on an old cloth and rubbed off the remainder of the rubber - again with my thumb nail.
Jan 08, 2013 | Bialetti 20-9 Stove Top Espresso Machine
I melted the rubber seal in my 4 cup Bialetti coffee maker. I forgot to put the water in it. Now I am trying to remove the smelly melted rubber from inside the threads and and coffee holder. Please how can...
I have the same problem. Scraped most of the rubber off mine with a knife. I'm going to try steel-wool next, as the whole thing is stainless-steel (or perhaps in your case, Aluminium), it should take a good sound beating.
I wonder if there are any solvents that would dissolve the rubber?
Apr 13, 2011 | Bialetti 20-9 Stove Top Espresso Machine
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
I want to change the rubber seal on a bialetti coffee maker
Just take your coffee maker apart and look under the top part. You'll see the seal and the metal filter. They are only held there by the friction of the seal itself (and any crud that might have built up by now). So with your finger nail or a butter knife pull out the seal, and with it will come the metal filter. It's not a bad idea to do this every time you clean your maker anyway. To replace with old or new seal, just put it back in place: first metal filter, then seal. Easy as can be.
Apr 21, 2010 | Bialetti Venus 4 cup stainless steel...
Bialetti 8853 Espresso Machine Logo
591 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
