Question about Vacuums
Dirt Devil Ultra: grinding noise, burning smell,brush not turning
I have a Dirt Devil Ultra handheld. Last time I used it, there was a sudden, loud, noise. It sounded like something jammed in the vacuum and caused the parts to grind to a sudden stop. Then, the brush stopped rotating and there was a burning smell and grinding noise. My husband took the vacuum apart and put it back together, but it still doesn't work. What should I do? THanks
  • 97 Answers
This sounds like the motor went out
Posted on Jul 20, 2009
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Loud motor burning smell
beater brush is most likely blocked, belt is turning -- UNPLUG UNIT, Clear obstruction and clean unit thoroughly... should be fine.
Feb 13, 2011 | Dirt Devil UD40130 Featherlite Bagless...
Dirt Devil R088100. Cloth Was Sucked Into Hole Below Dirt Holder
Brad, Hopefully it is the belt that you smell burning. I would start by removing the underneath side of the vacuum head. Normally just a few screws that are meant to be remove for general maintanence and circumstances such as this. After removing the screws this should reveal the dirty side of life to you. You may need to remove the roller brush, and inspect the ends to make sure the brush rolls freely while holding the ends. If not the ends may need to be cleaned of hair and strings: ends should pop of and a shaft runs through the middle connecting them. Clean and replace. Move on up the path the dirt travels. The neck where the head and vacuum come together is the next jamming point, if this is where the cloth is lodged chances are the motor may have over heated due to clogging. Your vacuum may have a automatic shut off. You will need to contact Dirt Devil to see if there is a reset for the motor. There are propellers / fan blades at the end of the neck just before the motor housing. This is most likely where the clothe has logged itself causing the brushes on the electric motor to emit the burning smell, if you can remove all obstructions and the unit still does not turn on, check with dirt devil about the reset, Hope this helps.
May 25, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
No power
My dirt devil just did the same thing to me. I cleaned the filter super good, checked all the hoses for clogs and the brush for tangled strings. Plugged it in and it worked! Yay!!! Hope this works for you too. Linda
Mar 18, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil M088174 Rattling Noise
You may need a new brush roll. The ends should turn easily,
Dec 26, 2007 | Dirt Devil M088175 Extra Light Upright...
DIrtDevil Ultra Handheld - No Suction & Brush not moving
take everything back out and make sure everything looks fine, then carefully put it back in do not force anything or it will bind up.
Dec 03, 2007 | Dirt Devil M08100RT Classic Handheld...
My vacuum is making a horrible noise!
I solved my own problem. I bought a new vacuum.
Aug 13, 2007 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
629 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
