SOURCE: Cigarette lighter doesn't work.
replace the fuse anyways... actually tho.... does the radio work as it is usally on the same fuse
SOURCE: which is the cigarette lighter fuse for a 98 jetta
It's a 15 amp (blue) fuze located above the relays on the fuse box. You need to remove the plastic fuse housing under the dash (two screws) and unclip the fuse tray and drop it down. The clips are white and are on the sides of the fuse tray, they just snap and swing back. Once you drop the fuse tray you will see several fuses above the relays. The blue one goes to the cigarette lighter. What a pain.
SOURCE: My 2002 VW Jetta cigarette lighter will not work.
You need a dc current test light to see if it is getting current, or plug in a cell phone charger to see if you are getting current. Our it could be the the lighter insert, a burnt out element and not the socket.
SOURCE: How to fix the cigarette lighter light (orange ring) on an Jetta?
you have to replace hole lighter.
SOURCE: cigarette lighter on 98 jetta doesn't work
yes: there is a 15 amp fuse for it located above the relays in the drivers side of the car.. I found it was the top one of the 3 fuses. it is almost impossible to see theses unless you remove the bottom section of the dash under the stering column.
