Question about ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard
Installed m/b and components and turn the system on......nothing happens. The green light on the motherboard comes on but the fan on the board nor the power supply comes on.
  • 34 Answers
Make sure you didn't forget to plug in the cpu-power-cord (4 pins, squarish)
Posted on Jul 20, 2009
Wii system warning issue
Do other games work on it because you might just have to professionally clean the game disk.
Jun 25, 2012 | Nintendo Wii Console
I have a dell dimension 3000 that kept powering on and off on and off repeatedly. Its xp and I thought it was the power supply. I tried installing a correct power supply but nothing happened at all. I...
What you can do is to reseat all cables that are connected to the CPU. Also, try reseating all components connected to the motherboard. that includes the RAM, Video Card, etc. Here's the proper way to reseat them.
First, remove everything from the motherboard then install them one by one. Once you installed something, try to boot it up. until you have isolated the cause of the problem. The most common cause of this kind of issue is the memory(RAM).
That's what you need to do before you throw your desktop away.
Hope this helps!
Sep 13, 2011 | Dell Dimension 3000 PC Desktop
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Flashing red light when ipod installed
power supply, known to band w, report to b and w service if you have not already.
May 31, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Tv turns on but nothing will work
If the green light come on but you cant get the menu to populate then the video board has gone out. We have installed hundreds of these in commercial applications and this has happened a few times. New LG LCDs in that size range are around 399 which is close to what it would cost to have it repaired (probably around $240.)
Nov 23, 2009 | LG 32LG30 32 in. LCD HDTV
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Newly installed HD now PC does nothing
Check the BIOS and make sure it's doesn't still have to old HD in there. Are you seeing anything on the screen?
Hit F12 to get into system setup and find out what HD options you have.
Jul 05, 2008 | Dell Dimension 4700 PC Desktop
Nothing happened when installed new computer - Please help
since the components are new,it must be other problem...I think that the problem is at the motherboard's jumpers...the power button, the restart button have wires that connect them with the motherboard so, u must not mess up the jumpers...i suggest u should download your motherboard manual and see exactly how the new components should be installed...
HERE, HOPE IT HELPS...
http://users.iafrica.com/g/gl/glynhall/hohweb/manuals.htm
Nov 26, 2007 | MSI K8D Master -FT For AMD Dual Opteron...
Power light on but still not working
Check ur firmware, (if ur PSP installed custom firmware e.g. OE, M33.) goto "recovery mode", press and hold R(right button) while turn on ur psp. if u can go, simple use pandora battery for downgrade/upgarde ur psp. see at, http://e-arena.blogspot.com
Oct 22, 2007 | Sony PlayStation Portable (PSP) Console
ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
