HELP!PLEASE!
If you have win 7 on a disc and you want to put it on the hard drive , try this
on start up hold down alt+ delete to get into bios
change the boot up from hard drive to cd as primary start up boot up
put the disc in a cd and close it down
restart and the pc should then boot from the disc in the cd drive
you should be able also to simply put the disc in the cd, go to computer , click on the cd drive and run and that should put the win 7 on the hard drive
talk with a computer shop for other ideas as to how to do it if that doesn't work
Testimonial: "I have it on a USB stick, I can't get that going at all"
I had a similar problem for linux ubantu operation system
it was downloaded to a stick and when I went to use it would not work-- would not load onto the hard drive
during experimentation I copied the stick to cd disc and installed from there no problem
may be if you tried that it may work copy stick to disc and see if that works
or as suggested talk with a computer repair shop for ideas
