Question about GPS
Will establish but will not hold link with satellites
    Brigadier General:
  • 4,090 Answers
1 battery too low in power
2) battery needs replacing
3 in a bad location
but possibley more #2
Posted on Jul 22, 2009
It soes not a acquire a satlelite.
I have this unit and have not had a problem acquiring satellites except under dense canapy cover. In open view you should always be able to acquire enough satellites. You should be able to see the available satellites on the start up screen and watch them being acquired. According to the manual if a satellite fix is not established a list of solutions is suppose to appear. Hope this helps.
Feb 02, 2011 | Garmin eTrex Vista Cx GPS Receiver
MY TOMTOM ONE WILL NOT PICK UP A VALID GPS SIGNAL
The Tomtom devices need to locate GPS satellites in the sky in order to work. Unlike TV satellites, these do not have fixed positions but move relatively to the ground. The Tomtom can locate them by scanning the hemisphere, but this takes up to ten minutes after you switch on the device.
To speed up the process, the Tomtom receivers can use a helper file stored on the device. It holds precomputed positional data for the GPS satellites that makes finding them a matter of a few seconds.
However, the file holds precomputed data for some two weeks in advance only. After this period, the Tomtom device has to resort to the slow scanning procedure.
You will need to connect your Tomtom device to a PC with the "Tomtom HOME" software installed, available from the Tomtom company web site. Use the software by following the onscreen instructions to update the package "QuickGPSFix" at least once every two weeks and you will find your device much more swift in establishing GPS connection.
Note also, all GPS devices require clear view of the sky. They do not work inside buildings, in tunnels, through the roof of the car, and even trees or buildings near to the car may compromise GPS reception. Make sure the device is mounted in an area of the windshield where it can "see" the satellites.
Some cars have metallic a coating on the windows (used for sunlight filtering and "can look outside - can't look inside" fancies). There are reports that these coatings also interfere with GPS receivers' ability to receive the satellite signals.
Jan 05, 2011 | Tomtom ONE GPS Receiver
Not getting a GPS signal. What do I need to do?
Usually, after you turn on the GPS device, it may take a minute or so to start up and lock into the satellite signals. While it is waiting to get a valid GPS signal, it is "listening" (scanning) for satellite signals to establish your current location.
If you are in the open outdoors, i.e. not inside a building or under extended covers, it should get the satellite signals within a minute or so.
If you still can't get a GPS signal, consider shutting it down ... using a "hard" shut-down (hold down the on/off button for 5 seconds or more ... to re-boot the system/software programs. Then, wait a while before starting it up again. Make sure your device is plugged in and/or the battery is NOT low when you're doing this.
Jan 02, 2011 | Tomtom GPS
Poor gps reception on tomtom xl 340
Dec 23, 2010 | Tomtom XL 340.S GPS Receiver
I can view the camera inside the home where my
There are several possible answers, but you need to supply more information. You did not say how you get to the Internet, which company, cable, DSL, or satellite? Most satellite companies will not allow cameras to be seen outside the network.
Sep 29, 2017 | D-Link DCS-5300 Network Camera
Garmin nuvi 650 cannot establish satellite link
go to garmin.com and down load new soft ware.
Dec 06, 2009 | GPS
I am in Sydney and the navman can't establish a signal. it remains stuck on the location it last got 'lost' on and cannot find a location.
in Australia you have to hold it upside down!
Seriously though the battery has to be fully charged to obtain a signal also in the middle of the city it may not be able to see clearly the birds . Other electronic factors can screen out connection.
Is it reporting a valid antenna connection in the pic that shows the satellite connections beoing made?
thanks for using FIXYA
Sep 27, 2009 | Navman F15
Unit taking long time to establish satellite connection?
5-7 mins is not unusual in many cases. Battery condition has a lot to do with the time it takes to establish connection. Recharge or replkace batteries with better quality ones and keep well charged up if you use rechargeable ones
Jul 23, 2009 | SkyGolf SkyCaddie SG2 GPS Receiver
Feature 71
If you have a manual, look up RECALL or FLASH or LINK. Specifically Feature 70 and FEAT 71. In your spare button set, you probaly have gray buttons labeled CONF/TRANS and LINK. Now you use them depends on how you are transferring calls. Are you on Centrex or do you have 3 way Conference calling from the telco? That's the one where you can establish a 3 way call and hang up and the other two parties stay connected. If you have that, you'll use the LINK button to get second dial tone, dial your number, and press LINK again to establish a 3-way. LINK time is defaulted at 600 mS, and is adjusted in A 4. Misc programming under LINK. You may just have 3-way calling, and that means the middle party has to stay on the call.
If you don't have 3-way conferencing, you can use the system to conference (using two lines), and the CONF/TRANS button. There may be some disconnect supervision (ie DS cabinet) issues, Supervised/Unsupervised programmnig changes, and transmission losses in conferencing, so your mileage may vary. Best would be maybe to conference with a VoIP trunk or other lossless facility. Anyway, you put the first call on hold, make the second call, then press CONF and the held line to establish a 3-way. At this point, if you have Disconnect Supervision, you can press conference again and leave the call, or put the call on HOLD to keep it on your phone and the other 2 parties can still talk to each other.
Carl
Jan 27, 2009 | NorStar M7324 Telephone
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is indoors, it may not acquire satellites.
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
GPS Logo
24 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
