Question about Philips 32PT9100D 32" TV
32" tv philips
Tv turns on with no picture only sound then turns off with the power light blinking
  • Philips Master
  • 1,550 Answers
Re: 32" tv philips
Checa una resistencia de bajo valor en la base del cinescopio.
Posted on Mar 17, 2008
0 characters
3 Points
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
T.v. won't turn on.
need to replace power inverter board if need to contact call 304 885 0225 shon
Feb 09, 2009 | Philips Magnavox TS3260C 32" TV
Phillips TV Sometimes Come's On No problem and Then Not sometimes with Green blinking light
Oct 13, 2008 | Philips 32PT6441/37 32" TV
Tv power light flashes on and off, but no picture or sound
the problem is, the system control or "jungle" ic as the call it was malfunction need to replace.need more help....dnlsabangan@yahoo,com.
Feb 15, 2008 | Toshiba 36A61 36" TV
Power light blinks repeatedly on my Philips TP3284C
Defective Horizontal output, or Flyback shorted. Need to Check up.
Jan 20, 2008 | Philips TP3284C 32" TV
Blinking LED and auto turn off
The repair kit comes with instructions for a skilled tech.......
Part # 483531057673 Horiz driver.......All L04.1U Chassis.....T.
Dec 22, 2007 | Philips 32PT6441/37 32" TV
No picture or sound
Classic power supply or horizontal output problem. Take it to a servicer.
Oct 18, 2007 | RCA F32450 32" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Open Questions:
See all Philips 32PT9100D 32" TV Questions
Philips 32PT9100D 32" TV Logo
115 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
