Question about Remington Polesaw Wizard
Pole saw lock broken when i extend handle need new lock
Where can i order new lock for pole.
  • gcfire3retir Jul 20, 2009
    yes the flip handle that you use to lock the pole broke off the locking assembly. I was told part number is 121560-01.unable to find. Thank You
  • ProHydroRace May 11, 2010
    Are you looking for a pole lock? Will Kurpinski do?
  • 188 Answers
I just contacted Master Parts and they have that part available (121560-01). You ca contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 20, 2009
Use a hose clamp on the inner pole.
Posted on Aug 25, 2009
How do you attach the chainsaw to the pole?
You simply mount the saw between the two metal plates.
There are two screws holding the plates together.
Look in the owners manual and it will guide you how to attach the saw.
Once the saw is attached, plug in the power cable that is on the end of the pole. One word of advice....there is a large locking collar ring that enables the two poles to extend and lock together. There has been numerous reports that the locking collar ring splits due to overexersion. You can add a stainless worm clamp (similar to a radiator hose clamp) around the rind and tighten it securely. Be sure it is a heavy duty wide clamp. This will help to keep the ring from splitting under pressure.
Jun 25, 2014 | Remington Electric Pole Saw
I need a Coupling Nut for my electric pole saw
lots of luck there, if you have tried Remington, with no luck may i suggest a automotive hose clamp and a piece of inter tube.
Nov 07, 2013 | Remington Electric Pole Saw
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Broken part for the pole attachment
RemingtonPower has stopped production of everything except unhappy customers. Replacement parts are almost exhausted.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "111182-01" into the "Part #:: window, then clicked search.
  • Click the 111182-01 - USE REPLACEMENT PART # 111304-01 "View Part" link.
Results follow:
Part #: 111304-01 Price: $15.00
Description: CHAINSAW BRACKET 747
If this is what you need I suggest you order it soon here:
If you have questions, or need assistance with any of our services, please do not hesitate to call our customer service team at 1-800-475-5660.
Please use the phone and get a name of the person providing service. HTH
Lou
Nov 12, 2009 | Desa International Remington 14" Electric...
I have a 36 volt recepicating saw. the handle is
There may be an underlying problem inside the handle. Sometimes the little nubs where the screws anchor crack inside the handle and will just turn when you try to tighten or loosen the screw. If you cannot back off the screw from the handle the nub is more than likely broken off from the handle. If this is the case you should order a new handle set from dewalt. You can then remove all the screws and then the little nub with a set of locking pliers. You could try to super glue the small piece back to the handle but it will fail eventually. If you have any questions please post back.
Oct 08, 2009 | Dewalt Saws
The clamp that secures the pole when extended is broken what is the part number?
There are a few web sites you can go to for parts. But, if all you need is a part number, I need the model and may need the serial numbers to find the correct part.
Sep 29, 2009 | Remington Electric Pole Saw
Need locking latch for Remington Electric Chain saw
You've got the one version of the Remington Pole Chain saws that doesn't have a separate parts breakdown online.
However, here's a owners manual for your pole saw and a parts breakdown that can be used for most replacement parts, as the RPS-96 is a similar version of your model.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
You might want to contact the factory to verify that the parts are the right ones before ordering them by calling 1-866-672-6040
Hope you find this very helpful and best regards!
Aug 07, 2009 | Garden
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Remington Polesaw Wizard Logo
230 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
