Hi there... where do I find the fuse that is allocated to the cigarette lighter? I have looked under the steering wheel and under the hood and I can't seem to locate it. Would you be able to help me. I have a 2008 Honda Civic Hybrid
thanks.... have found the panels... just can't identify the accessory/cigarette lighter fuse..... all seem well numbered EXCEPT the one I'm looking for ... damn :)thanks.... have found the panels... just can't identify the accessory/cigarette lighter fuse..... all seem well numbered EXCEPT the one I'm looking for ... damn :)
You can't post conmments that contain an email address.
The Acc/cigarette lighter fuses are #28 and #29 of the inside fuse panel. #28 is for the rear outlet and #29 is for the front. The both appear to be outlets however and not a cigarette lighter, unless you ordered the vehicle with that option.
Good luck.
Regards,The Acc/cigarette lighter fuses are #28 and #29 of the inside fuse panel. #28 is for the rear outlet and #29 is for the front. The both appear to be outlets however and not a cigarette lighter, unless you ordered the vehicle with that option.
Good luck.
Regards,
maybe try taking all fuses out one by one to see if any have blown, also look if there's brown residue on fuse legs doesn't help so rub with little sand paper to clean
put your low lights on,see if sigaret lighter lids up. box under steeringwheel.take out one by one and see whit fuse, light goes off.is also possible in the cover off the box is indicated whits one it is
in a 98 mustang, the fuse's for the cigarette lighter and the axillary are under the steering wheel to the left.. the black cover pops off, some have extra fuses in the lid too
If by "power Outlets" you mean the cigarette lighter, the fuse is generally the same line as the interior lights, or the radio.
The Fuses are generally located in either of 3 places: 1. When you open drivers door - on the side of the dash a panel can be removed., 2. Just directly under the steering wheel, perhaps a panel is right there, below and or to the left of steering, or under the dash at this location, again to the left of the steering wheel. 3rd, some fuses may be located in or behind, or under the glove-box.
There is also a power distribution center (a black box with fuses and relays) next to the battery under hood. The cover can be removed and under the inside of the cover a description of fuses and relays are written here, typically. The cigarette lighter fuse would be on the inside of the cabin in one of the areas as described above.
Hope this is what you are looking for - even if it isn't the cigarette lighter fuse, you can find the fuse that you are looking for in one of these locations. Good luck. Canada E1A 2H4
all cigarette lighters in vehicles are ran to a 12 amp fuse. look wherever your fuse panel may be (under the hood, in next to the steering wheel) and see if you need a new fuse. good luck
Definately sounds like a fuse if 2 locations are not working. Cigarette lighters are 2 wires to hook up so to have a faulty port is highly unlikely. Check your owners manual for the fuse location. It will probably not be under the hood in that fuse box but under the steering wheel up and under the dash. No big deal though.
Check your owner's manual if you have one. It will tell you the locations of your fuse boxes.
On my '03 corolla, there is a small enclosed one to the left of my steering wheel, under the dash. Maybe yours is in the same location. hope this helps...
There's one under the hood, on the right side... labeled Fuse Box and then there's another on the left side of the steering wheel, near the signals, behind the little fold out compartment (which you have to take out to get at the fuses)
