Question about Canon PIXMA Pro 9500 InkJet Photo Printer
When I get ready to print something, it won't print - something is going on with the roller or the feeder. I've tried several times to print out something, and each time, I try to print, nothing prints out. What should I do? Is it cheaper to have it fixed or buy another one? Thank you. TIna Humphrey
  • tinahump Jul 20, 2009
    I forgot to mention, the paper won't even go through the feeder. It just stops or gets jammed up - do I still need the Canon special lube for the paper transport? And where do I get this products from?
    Thanks
    Tina
    President:
  • 2,306 Answers
This is a good printer, if the paper is blank you may need a purge assembly, if there are 11 blinks of the error light it just needs Canon special lube for the paper transport. Definitely worth the repair...
Posted on Jul 20, 2009
Sharp ar5316 will not load paper from feeder tray or something it grabs it but does not go round the rollers for printing... any idea what the issue is..
i think youre problem is youre clouth casset paper
you have to open back cover
2- close dricer
3- close cloth
4- service cloth
Apr 21, 2017 | Sharp Office Equipment & Supplies
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
When ready to print paper only goes through a little and then message says paper jam..it now happens all the time
If you have had your printer for some time now it could possibly be that the feeder rollers are worn and aren't picking up the paper correctly, causing the printer to think it is jammed. The rollers don't have to be changed very often, but they do get old. A new roller kit will cost you anywhere between 30 and 50 dollars online. They are super easy to install. The only thing to make sure of is: don't order a full maintenance kit. Yes, they have the rollers, but they are most likely going to send you a fuser as well, which will triple the cost. Try to find just the rollers. The replaceable rollers are; the transfer roller, paper pick-up roller (which is probably your problem), cleaning roller, and separator pad (also one that has to do with the paper).
Aug 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Paper feeder is off so paper gets stuck
Hello , sometimes what happens is that there could be objects blocking the path of the paper on one side. Maybe a paper clip or a pen, I have seen this many many times. Just turn off the printer and remove the paper from the feeder. Unplug the printer from the power cord. Then flip the printer upside down and shake it a little most of the times you will find something stuck in there and it will fell down. If you do not find anything maybe then there is something wrong with the feeder roller. Also try the following link http://bit.ly/9nrlMW
Feb 03, 2010 | Lexmark X5150 All-In-One InkJet Printer
DOCUMENT FEEDER
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Canon imageCLASS D760 All-In-One Laser...
Re: Paper Jam
most likely something jammed down deep, or the rollers need cleaning..
Mar 28, 2008 | Lexmark T520 Laser Printer
Paper feeder
Hi, most printers usually have rubber pickup rollers that get worn out with time. Usually cleaning the rollers with rubbing alcohol will restore the rollers for a while. Sometimes getting to the rollers takes a long Q-tip but cleaning with a rag is best. Good luck.
Aug 28, 2007 | HP PSC 500 All-In-One Printer
Lexmark X5250 PAPER WONT AUTO-FEED
Very pesty!!! Ok, it may be a paper feeder issue. It could be a partially jammed roller or carriage, open up unit as if you were to change cartridge, use a torch to check for the tiniest paper block or foreign material. You would be surprised what can fall or accidenatlly get in them...funny that, i just cleared a tiny piece of toddler debris from my lexmark, and i missed it the first time. Also, paper sensors can start to go and die, hope it is not this!!! as it will need replacing if it is. If it is printing, it may also be too much info from pc to printer. Does it only do this at certain times or all the time? Try clearing the print jobs memory by printing a small document but click on print icon and choose cancel all print jobs. Wait until it does. Try printing again. Also open notepad as if you were to print it, right click on file and print, and check if printer says ready...indicating it is functioning status. this can help diagnose problems sometimes it will give you an error code or message you need.
Aug 11, 2007 | Lexmark X5250 All-In-One InkJet Printer
Canon PIXMA Pro 9500 InkJet Photo Printer Logo
145 people viewed this question
old marine
old marine
