Question about Remington Sport & Outdoor - Others
Need a replacement seat for my 300 mag treestand
When was it made
This ammunition was first made in 2001.
300 Winchester Short Magnum
Nov 11, 2015 | MAG Optics
Replace original bike seat
Lefty loosey, righty tighty. Counter clockwise. Also, check to see if the bolt is rusty because it may be seized. Some penetrating oil can help in this instance.
Mar 03, 2014 | Trek Navigator 300
Serial numbers winchester: bolt action #39163A, barreled by Griffith & Howe.
Griffin and Howe were out of business before the 300 win mag was introduced.
Sep 24, 2013 | Remington Model 700 BDL LSS Bolt Action...
Can I leave the tree stand outside when not using it?
It is not recommended to leave the treestands outside for long periods of time. If the stand's tubes are filled with water and the water freeze it may damage the tubes. Also, the ropes, the seats or other parts of the stand may be eaten or damaged by animals.
Jan 14, 2013 | Hunting
The light on my Ashdown mag 300 combo input level does not light up. How easy is it to fix. Electronic places charge 85.00 just for a quote and 85.00 and hour plus parts to fix it. HELP!.
If you mean the light in the meter, those can be hard to replace and mosts shops would replace the meter itself which would up the cost. It is probably a 12 or 14 volt bulb(s). Look at the back of the meter and see if there is a removable socket to get at the bulb... if not, then the bulb(s) is internal and probably a soldered in grain of wheat bulb(s). If you have never worked on meters before it takes GREAT care to keep contamination out when working on them. I would certainly not pay $85 to have bulbs replaced... use an external lamp if you really need to seee the meter... one of the little LED ones would work.
Sep 12, 2011 | Ashdown MAG C115-300 Combo Bass Amp
Where is the tire lock kept on the 2002 RX 300
If you are referring to the mag wheel puzzle lock, storage is an optional location. The RX300 has a number of storage pockets, so check the spare tire area and tool kit, then the rear storage side pockets, glove box, console sliding drawer at bottom of console and your map pockets on the doors. If the puzzle key is missing , go to the dealership. They will have a matching master set and can order a replacement after identifying yours.
Nov 01, 2009 | 2002 Lexus RX 300
Remove rear seat lexus es300 2008
the bottom of the rear seat pulls straight up at the front and out. its pretty tight, you need to pull very firmly.
Oct 19, 2009 | 2003 Lexus ES 300
Passenger seat back will not move either direction
Motor on the seat may have gone out, contacts in switch got dirty or worn, or assembly reached limit and stuck. Try sitting in it pushing back hard and adjust. If not youll need to replace switch,b take seat apart to fix or replace.
Dec 06, 2008 | 1989 Mercedes-Benz 300-Class
Sport & Outdoor - Others Logo
318 people viewed this question
Top Remington Sport & Outdoor - Others Experts
Tom Chichester
 steve
steve
Are you a Remington Sport and Outdoor - Other Expert? Answer questions, earn points and help others
