Question about Steamist SM-79 7900
I have the SM-15 unit. It contiuously pulls water into the unit and as a result both steam and water comes through into the shower.
  • 19,396 Answers
That means that either the inlet valve is stuck open, or the control panel that is supposed to open and close the inlet valve is faulty.
This is tested by the technician accessing the inlet valve located inside the steam generator, near to the main faucet to the wall, and testing if it is stuck open.
The valve is tested by reading continuity on valve solenoid, and energizing the valve to check if it does close.
If the valve is fine the technician will test the control board reading voltages out.
A good Idea would be Contacting Steamist, to book a technician and to check if part or repair charge can be covered.
The job can also be done by any local appliance technician, contacting steamist first is a must.
Regards.
Posted on Jul 20, 2009
Turn on steam in shower, but no steam comes out
So many things could be wrong. 1 check circuit breaker. 2. Check there is water going to steam unit. Power to control in shower? Steam unit could be burned out. Or control is not working or thermostat not working.
Apr 08, 2015 | Electrical Supplies
Water is pouring out of pipes where steam should be coming from- ? - Please advise
Paige - your question appears in the "Shower hardware" section.
Steam - from a shower head?
Water should be coming from a shower head and steam is in your radiators - not the other way around. Please provide more info on the products or system you're having this trouble
Dec 10, 2014 | Home
SM-9-901 Generator Steam Shower
There are three things that affect this:
1. Incoming water temp.
2. Incoming water volume.
3.Temp of the device.
There are some other minute things like humitidty and altitude too.
Jul 21, 2013 | Steamist SM-9-901 Generator Steam Shower
The humidifier does not collect water at all
Hi,the lack of water in the bucket, may be a result of the humidity setting on the unit being to high. Try setting the level at 45% or lower. Also, be sure there's adequate air flow around the unit itself. It should remain a minimum of 12' from a wall or furniture. 24" is better.
If the above doesn't solve the problem, try this at home test. Place the unit in the bathroom, turn it ON and set the level as low as possible. Turn the shower ON hot enough to generate steam. Do not turn ON the bathroom's exhaust fan. As you exit the bathroom, close the door. Wait 15 to 20 minutes, before returning to the bathroom. When you do, turn the shower OFF and allow the unit to run for several more minutes. Then check the bucket for water. If there is any sign of water in it, it's working fine. It was probably a case of the humidity level being set to high the first time.
If there was no water in the bucket, the refrigerant gas in the cooling coils and the compressor may need recharging.
Hope this helped your to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Maytag M7DH65B2A Dehumidifier
There is no water coming out of the machine at all. No error light come on but when you go to make a coffee with beans or pre ground it goes through the process but just dry coffee comes out. Also no water...
For the steam check the end of the nozzle to make sure it is not blocked.
For the coffee run a coffee using the pre ground method but without coffee grounds, if water comes out then grinder is too fine, if no water remove brew unit and clean top shower screen, you might have to clean tube leaving from shower to discharge.
Aug 29, 2010 | Gaggia Syncrony Compact Coffee...
Water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Feb 26, 2010 | Delta & Leland Lavatory Faucet
When I turn the faucet to hot ,water comes out of the shower without pulling the shower pullup
either to much water pressure to unit or pull up is clogging /damaged if u have separate valves on water supply start at half way and work ur way open or close till water doesnt come out of shower head
Feb 15, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Steamist SM-79 7900 Logo
192 people viewed this question
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
