Question about Black & Decker Mouse Sander/Polisher
Cannot register my blackanddecker 4 1/2" angle grinder
I bought it 7/19/09 at walmart cat.number 7750 I paid $29.97 dollars plus tax 9.75% internet won't let me register it,WHY I donot know,maybe you do ?????????
  • 2,176 Answers
Go to BlackandDecker.com and in the header area on the right side you will see a link to register tools.
Posted on Jul 20, 2009
GHOSTSURF 2007 PLATINUM CAN'T TAKE THE SERIAL NUMBER
Contact best buy with your email or card details hopefully they have records.
Aug 22, 2017 | Computers & Internet
I just bought a hand grinder from a guy but don't know how to take the disc off . it has a button u push but no nut on the disc
If there isn't an arbor nut holding the blade/disc on the grinder you have a disc with the threaded center built into it. While holding the arbor lock button down you have to turn the disc by hand until it breaks free and spins off. It may be on vary tight as it is a self-tightening thread so the disc won't come off while you use it.
Feb 22, 2012 | Black & Decker Black And Decker 4-1/2"...
The worm gear is stripped. Is it replaceable?
I just checked their site and don't see any internal parts available for this tool. I would recommend calling them before doing anything else. the site I used is dewaltservicenet.com
Aug 21, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
How do I remove the cover of the black and decker angle grinder.It stopped working,I think a wire is loose inside,but i cannot get it open to see if I am right. Can anyone help? Thanks. Gerry
Hi Gerry,
The body of the grinder should be in two halves. Normally there are two or more screws holding the plastic parts together but these may be hidden behind plastic stoppers. See diagram:
http://servicenet.blackanddecker.com/Products/DetailDiagram?isId=true&productNumber=11651&selectedType=16337#
Remove the screws and it should be possible to split the case.
Hope this helps!
Apr 27, 2011 | Black & Decker 4 1/2" Small Angle Grinder
I have a 7" angle
There are 3 versions of the 7" grinder model 4074. Sears Parts Direct has the manual for sale http://www.searspartsdirect.com/partsdirect/part-number/BLACK-DECKER-Parts/Grinder-Parts/741333-00/0009/900/Model-4074/1228/0721050?keySuffixId=NA&productTypeId=x&searchModelNumber=4074&subCompDesc=Unit%20parts&brandDesc=BLACK&DECKER&modelDesc=7 .
Black and Decker has pdf versions of the manuals for many of their products are here: http://www.blackanddecker.com/manuals.aspx . However, check the model number on the grinder. 4074 doesn't come up as a valid model. The usual model numbers start with alphabetic characters to indicate the type of tool. The site lists where to look for model numbers.
I hope this helps.
Apr 26, 2011 | Black & Decker Garden
Need new brushes
Match them up at ace hardware. Pull the screw out of the back by the cord. And slide that half down. Your brushes are exposed. Use the same spring that was in before and toss the new ones, unless they are close to the original. The ones that matched a recent 7750 (type 3) was #61702. Good luck.
Apr 10, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
I need replacement brushes for a B & D 7750 4.5" grinder and can't find a source. Any ideas? Thanks.
This is considered a throwaway tool when any internal parts break or wear out, including the brushes. It's usually cheaper to buy a new one as opposed to repairing one. If it's still within the warranty period, B&D will replace it or prorate the value depending on how long you've had it. The only replacement parts available for this grinder are the side handle, blade guard, the inner and outer flanges and spanner wrench.
Dec 18, 2010 | Black & Decker 7750 4 1/2'' Small Angle...
I borrowed a B&D 7750 3 to cut off the legs on a wire shelf system. I would like to replace the grinding disc but it appears to need a special tool to remove the disc. Is that correct? The owner says...
Yes you need an angle grinder spanner/wrench. It is like a tool with two pins that fit in the holes of the grinder disc securing nut. You can see a picture of one here: http://images.toolspot.co.uk/Angle%20Grinder%20Accessories/Angle%20Grinder%20Spanner%20For%20412in.jpg
They do come in different sizes, but you can also buy adjustable ones. Your best bet is to take the grinder to the local hardware store, big box outlet or anywhere power tools are sold and they should have a grinder spanner to suit your grinder.
Jul 03, 2009 | Black & Decker 7750 4 1/2'' Small Angle...
Black & Decker Mouse Sander/Polisher  Logo
75 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Rabbit Brains
Rabbit Brains
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
