Question about Makita Saws
Having trouble assembling/ installing diamond wheel 41/2" can't get nut off to put wheel on
  • krisklassics Jul 22, 2009
    thanks so much for your offer of help. I finally got the outer flange off and was able to install the wheel. I had to stuggle with it for quite a while, so when I got the new blade on, I didn't tighten the flange any more than necessary! I used it to cut ceramic tile and I love it! My expensive wet saw will probably never get used again.
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number. Also on the diamond wheel do you have the insert for the center if required? Some diamond wheels require a special outer flange also. Let me know and I will try and help
  • 2,251 Answers
You need to use an air gun to get it off,i had same problem with my wet saw,go to a garrage and thet'll sap it off in 2 seconds with the air gun
Posted on Dec 15, 2009
  • Sal DeAngelo Dec 15, 2009
    sorry thought you were talking about a wet saw
    Sergeant:
  • 384 Answers
Turn otherway.
Posted on Jul 21, 2009
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
How do i remove the hub assembly from the front wheel of my 2001 dodge ram RWD?
  • Jack up your Dodge Ram. Block the wheels to keep it from rolling as you work. Get started by removing the first tire and wheel assembly. Remove the hub extension and the brake caliper as well as the caliper adapter.
  • Remove the grease cap, cotter pin, nut lock, nut, washer and outer wheel bearing. Now, pull the old rotor off of the spindle. Clean the area with a damp cloth to remove any debris. Pack the wheel bearings with grease.
  • Install the new rotor and hub onto the spindle. Replace the outer wheel bearing, washer, and then the retaining nut. Torque the nut to 30 to 40 ft. lbs. while rotating the hub and rotor. Then tighten the nut and install the nut lock and a new cotter pin.
  • Clean the grease cap and then coat it with new wheel bearing grease and replace the cap. Put the caliper adapter back into place and then tighten the two mounting bolts with a torque wrench. Install the wheel and tire assembly.
  • Repeat this process for each additional rotor and then lower the vehicle. Tighten the lug nuts and test drive your Dodge Ram to make sure that the installation was successful.
  • If I've helped, please vote!
    Dec 10, 2010 | 2001 Dodge Ram 1500 Truck 2WD
    I need to put in another steering collum and I dont know how to do it.its a 91 ford F150.hope you can help me.I got another one out of the junk yard for 125,00 is that a good price .thanks for helping my...
    I'd say $125.00 is a good price for a steering column.
    First, have to remove steering wheel (but I don't have instructions for the steering column. For that, maybe try alldata.com, but that will cost):
    STEERING Steering Wheel REMOVAL & INSTALLATION Without Air Bag EXCEPT F-SUPER DUTY STRIPPED CHASSIS MODELS AND MOTOR HOME CHASSIS MODELS Fig. 1: Remove the screws from behind the wheel - F-150 model without air bag 88288p12.jpg
    Fig. 2: Pull away the cover with the wiring still connected 88288p13.jpg
    Fig. 3: Disconnect the wiring at the steering wheel 88288p14.jpg
    Fig. 4: Matchmark the steering wheel 88288p15.jpg
    Fig. 5: Remove the center nut from the steering wheel 88288p16.jpg
    Fig. 6: Use a steering wheel puller to remove the wheel 88288p17.jpg
    Fig. 7: Remove the steering wheel from the shaft 88288p18.jpg
    Fig. 8: Correct steering wheel installation 84928058.gif
    NOTE: The factory recommends that the front wheels be set in the straight-ahead position and you paint or make chalk marks on the column and steering wheel hub for alignment purposes during installation. Of these two safeguards, it is more important to mark the column so even if the column is moved slightly, the steering wheel can still be repositioned in its original position.
    1. Disconnect the negative battery cable.
    2. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel. On vehicles equipped with the sport steering wheel option, pry the button cover off with a suitable prytool.
    3. Disconnect the horn switch wires at the connector and remove the switch assembly. On trucks equipped with speed control, squeeze the J-clip ground wire terminal firmly and pull it out of the hole in the steering wheel. Don't pull the wire out without squeezing the clip.
    4. Remove the horn switch assembly.
    5. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
      Never hammer on the wheel or shaft to remove it! Never use a knock-off type puller.
    6. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 40 ft. lbs. (54 Nm)
    F-SUPER DUTY STRIPPED CHASSIS MOTOR HOME CHASSIS MODELS
    1. Set the front wheel in the straight-ahead position and make chalk marks on the column and steering wheel hub for alignment purposes during installation.
    2. Disconnect the negative battery cable.
    3. Remove the one screw from the underside of each steering wheel spoke, and lift the horn switch assembly (steering wheel pad) from the steering wheel.
    4. Disconnect the horn switch wires at the connector and remove the switch assembly.
    5. Remove the horn switch assembly.
    6. Remove the steering wheel retaining nut and remove the steering wheel with a puller. WARNING
    7. Install the steering wheel in the reverse order of removal. Tighten the shaft nut to 30-42 ft. lbs. (41-57 Nm).
    With Air Bag Fig. 9: Remove the air bag module and disconnect the wiring harnesses 88288g00.gif
    CAUTION
    Read the air bag service precautions in Section 6 prior to doing work involving an air bag equipped steering column component. Always wear safety glasses when servicing an air bag vehicle and handling the air bag to avoid possible injury.
    1. Turn the front wheels to the straight-ahead position.
    2. Disconnect the battery-to-starter relay cable for at least one minute to let the air bag back-up power supply discharge.
    3. Remove the air bag module from the steering wheel (refer to Section 6).
    4. Disconnect the horn/speed control wiring from the steering wheel.
    5. Remove the steering wheel retaining bolt.
    6. Install the Differential Bearing Cone Remover/Replacer, No. T77F-4220B1, or equivalent, and remove the steering wheel. Route the contact assembly harnesses through the steering wheel as it is lifted off of the shaft. To install: NOTE: Make sure the front wheels are still in the straight-ahead position prior to installation.
    7. Route the air bag sliding contact wiring through the steering wheel at the 3 o'clock position. Position the steering wheel on the shaft an align the marks. Make sure not to pinch the contact wire. WARNING
      Make sure no air gets trapped between the steering wheel and air bag sliding contact.
    8. Install a new steering wheel retaining bolt, then tighten to 23-33 ft. lbs. (31-45 Nm).
    9. Connect the horn/speed control wiring and clip in place. Connect the air bag wire harness. Tighten the module retaining nuts to 35-53 inch lbs. (4-6 Nm). NOTE: When the battery cable has been disconnected, then reconnected, some abnormal driving symptoms may occur for the first 10 miles (16 km) until the PCM re-learns it adaptive strategy.
    10. Connect the battery to starter cable. Verify the air bag warning indicator light on the instrument panel.
    Sep 24, 2010 | 1991 Ford F150
    How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
    you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
    Removal & Installation
    1. Raise and support the vehicle.
    2. Remove the wheel.
    3. Remove the wheel drive shaft nut.
    4. Remove the brake caliper and wire aside.
    5. Remove the brake rotor.
    6. Disconnect the electrical connector from the wheel speed sensor.
    7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
    8. Remove the 3 hub and bearing assembly bolts.
    9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
    10. Remove the hub and bearing assembly from the steering knuckle.
    To install:
    1. Install the hub and bearing assembly to the steering knuckle.
    2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
    3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
    4. Connect the electrical connector to the wheel speed sensor.
    5. Install the axle nut to the wheel drive shaft and hand tighten.
    6. Install the brake rotor.
    7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
    8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
    9. Install the brake caliper.
    10. Install the tire and wheel.
    Sep 24, 2010 | Pontiac Montana SV6 Cars & Trucks
    How long does it take to fix front bearings on a 97 dodge caravan? and cost
    About an hour a side...This is the whole job and pictures....
    The hub and wheel bearing unit is serviced as a complete assembly. Replacement of the front drive hub and bearing assembly can be done without having to remove the steering knuckle from the vehicle. However, if the hub/bearing assembly is frozen to the steering knuckle, removal of the steering knuckle is required.
    2. Remove the cotter pin from the end of the stub axle. Remove the nut lock and spring washer. With the brakes applied, loosen, but do NOT remove the axle nut and washer with the vehicle still on the ground or damage to the wheel bearing will result.
    3. Raise and safely support the vehicle. Remove the wheel.
    4. Remove the front brake caliper assembly from the steering knuckle assembly and support from the strut assembly using a strong piece of wire.
      1. Remove the front brake rotor from the hub/bearing assembly.
      2. Remove the retaining nut and washer from the halfshaft stub axle.
      3. Remove the ABS wheel speed sensor from the steering knuckle.
      4. Remove the 4 hub and bearing assembly mounting bolts from behind the steering knuckle.
      5. Remove the hub and bearing assembly from the steering knuckle.
    5. To install:
      1. Thoroughly clean the mating surfaces of the steering knuckle and the hub and bearing assembly of any foreign material or nicks so the surfaces are clean and smooth.
      2. Install the new hub and bearing assembly and tighten the mounting bolts in a crisscross pattern to 45 ft. lbs. (65 Nm). Be sure the hub and bearing assembly is seated squarely against the front steering knuckle.
      3. Install the disc brake rotor.
      4. Install the brake caliper assembly onto the steering knuckle.
      5. Install the axle washer and nut. Tighten but do not torque.
      6. Install the ABS wheel speed sensor.
      7. Install the wheel and lug nuts. Torque the lug nuts, in sequence, to 95 ft. lbs. (129 Nm).
      8. Lower the vehicle. Do NOT roll the vehicle until the axle nut has been properly torqued or damage to the front wheel bearings will result.
      9. With the vehicle's brakes applied, torque the axle nut to 180 ft. lbs. (244 Nm). Install the spring washer, nut lock and a new cotter pin. Wrap the cotter pin prongs tightly around the axle nut lock.
      10. Reconnect the negative battery cable. Check the wheel alignment.
    The hub/bearing assembly is attached to the steering knuckle with four bolts
    Removing a hub/bearing assembly
    If the hub/bearing is "frozen" to the steering knuckle, separate the ball joint and lightly tap on the hub/bearing from behind
    The hub/bearing assembly should free itself from the steering knuckle
    About $60 a hub.
    May 23, 2010 | 1997 Dodge Caravan
    Havin troubles removing the rear hub on a F150
    1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer Maintenance/Service and Repair.
    2. CAUTION: Do not allow the caliper and anchor plate assembly to hang from the brake hose or damage to the hose can occur. Remove the bolts and position the caliper and anchor plate assembly aside.
      • Support the caliper and anchor plate assembly using mechanic's wire.
      • To install, tighten to 200 Nm (148 ft. lbs.) .
    1. Remove the brake disc.
    2. Remove and discard the wheel hub nut.
      • To install, tighten to 400 Nm (296 ft. lbs.) .
    1. Remove the wheel bearing and wheel hub assembly.
    2. If necessary, remove the wheel bearing from the wheel hub.
    3. CAUTION: Do not apply lubricant to the threaded end of the wheel spindle. NOTE: Clean the wheel spindle (including the threaded end) of any dirt or grease using the specified solvent before installing the brake disc. To install, reverse the removal procedure.
      • To ease installation, lubricate the inner race of the bearing assembly using the specified lubricant.
    Oct 31, 2009 | 2006 Ford F-150
    Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
    With Automatic Locking Hubs
    1. Raise the vehicle and install safety stands.
    2. Remove the wheel lugnuts and the wheel and tire assembly.
    3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
    4. Remove the snap ring from the end of the spindle shaft.
    5. Remove the axle shaft spacer
    6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
    7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
    8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
    9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
    10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
    11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
    12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
    13. Install the axle shaft spacer.
    14. Clip the snap ring onto the end of the spindle shaft.
    15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
    16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
    17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
    Jul 27, 2009 | 1992 Ford Ranger
    Removal of broken wheel studs on 2004 saturn ion
    line up the hole with the stud and beat it out with a 3or4 pound ball peen hammer.
    Jun 16, 2009 | 2004 Saturn ION
    Starter replacement - 1991 Toyota previa
    Here are detailed, step-by-step instructions for the removal and re-installation of your starter motor. Hope this helps! Have a great day!
    Starter Toyota Previa 1991-1997 Repair InformationREMOVAL & INSTALLATION
    See Figures 5 through 12
    1. Disconnect the negative battery cable from the battery.
    2. Raise and safely support the vehicle.
    3. If equipped with 4WD, remove the front driveshaft.
    4. Remove the nut and disconnect the starter wire.
    0900c15280089fbb.jpgFig. 5: Disengage the starter wiring
    1. Disconnect the starter connector.
    0900c15280089fbc.jpgFig. 6: Remove the cap hiding the nut 0900c15280089fbd.jpgFig. 7: It will be necessary to use an extension to remove the nut
    1. Remove the bolt holding the starter stay to the upper stiffener plate.
    2. If equipped with 2WD, remove the starter by removing the nut and three bolts.
    3. If equipped with 4WD, remove the starter by removing the nut, four bolts, and the center bracket.
    0900c15280089fbe.jpgFig. 8: Four bolts hold the starter in place 0900c15280089fbf.jpgFig. 9: The nut is located on the top of the starter 0900c15280089fc0.jpgFig. 10: Extract the starter from the engineTo install:
    1. If equipped with 4WD, install the starter, the center support bracket, nut, and the four bolts. Tighten the bolts as follows:
      • Bolt A to 41 ft. lbs. (56 Nm)
      • Bolt B to 30 ft. lbs. (41 Nm)
    0900c15280089fc1.jpgFig. 11: Bolt locations on the 2WD models
    1. If equipped with 2WD, install the starter, nut and three bolts. Tighten the bolts as follows:
    0900c15280089fc2.jpgFig. 12: Bolt locations on the 4WD models
    1. Install the bolt to hold the starter stay to the upper stiffener plate. Tighten the bolt to 43 inch lbs. (5 Nm).
    2. Install the starter connector.
    3. Connect the starter wire with the nut. Tighten the nut to 78 inch lbs. (9 Nm).
    4. If equipped with 4WD, install the front driveshaft.
    5. Connect the negative battery cable.
    SOLENOID REPLACEMENT
    The starter solenoid (magnetic switch) is an integral part of the starter assembly.
    1. Remove the starter from the van. Remove the heat insulator from the starter assembly, if equipped.
    2. Disconnect the wire lead from the magnetic switch terminal.
    3. Remove the two long, through bolts holding the field frame to the magnetic switch. Pull out the field frame with the armature from the magnetic switch.
    4. Toseparate the starter housing from the magnetic switch assembly, remove the two screws and the starter housing with the pinion gear (1.6 kW), idler and clutch assembly.
    To install:
    1. If necessary, install the gears and clutch assembly to the starter housing. Apply grease to the gear and clutch assemblies and place the clutch assembly, idler gear, bearing and pinion gear (1.6 kW) in the starter housing.
    2. Insert the spring into the clutch shaft hole and place the starter housing onto the magnetic switch. Install the two screws.
    3. Install the field frame with the armature onto the magnetic switch assembly and install the two through bolts. Tighten the bolts on the 1.4 kW to 52 inch lbs. (6 Nm) and on the 1.6 kW to 82 inch lbs. (9 Nm).
    There is a protrusion or tab on each part; make sure you line them up correctly during assembly.
    1. Connect the wire to the terminal on the magnetic switch and tighten the nut to 52 inch lbs. (6 Nm). Install the heat insulator, if equipped.
    2. Reinstall the starter on the vehicle. Check starter system for proper operation.
    Nov 23, 2008 | 1991 Toyota Previa
    Saws Logo
    96 people viewed this question
    Top Makita Saws Experts
    ray gallant
    Are you a Makita Saw Expert? Answer questions, earn points and help others
