Trial versions are free for 1 month
you bought the unit at a sale so if the trial version was installed , the free period is well over so you have to pay or uninstall
next point warranty is from day of sale . not day of manufacture so discuss that with the shop because for them to deny warranty full period means that it is not new but second hand and all you got was the remainder of the warranty period
In other words , you have been had
you can get brand new 1T hard drives for less than $90.00
SOURCE: just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
SOURCE: Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
SOURCE: Bought Western digital WD5000H1U-00, but
Memeo backup is an additional software. you can try it for 30 days and if you like it purchase it.
SOURCE: solve Bad sectors Problem?..????
irst connect your drive to computer then check its drive letter meand c: or d: or e:
then go to start > run> then type "cmd" then go to drive letter then type "chkdsk /r"
then it cheks your harddisk for eror.
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
I am not sure he did not clarify..I could barely understand his englist.. but it will not even let me into the harddrive.. he said something about manually copying and pasting files into it for it to work but idk?
Hi, To clarify, They told you something was a trial version, what was the trial? Were they referring to software that came with the drive? Chris
