Question about Frigidaire FEF336BC Electric Kitchen Range
Top element in oven not working
I have a Frigidaire FEF366BCA Electric stove, the top heating element in the oven does not work or does not get red (orange). I have remove the element and place a ohm's meter on the element this appears to be Ok. There are not burnt spots on the element. I have removed the wired hooks in the back of the stove and recrimped then down on the element connections but still no luck.
I have recheck the element again to found a lost connection but still no luck
.. thanks in advance
  • Topester Nov 20, 2007
    no comment
  • 248 Answers
This "top element" is your broil element. It will only get red when broil is selected.
Posted on Nov 20, 2007
Frigidaire FEF366CCB classic series electric oven. While I was away the oven stopped working. No heating elements in the oven or stove top at all work. The EOC still shows time, no fault code. Ideas?
check breaker or power feed my not be getting correct power to the unit may only be getting 110v which electronic circuits work on instead of the 22ov that the elements and coils work on
Oct 06, 2016 | Frigidaire Ovens
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
629 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
