Question about Price Pfister Plumbing
I'm unable to move the trim piece off by hand or with wrenches. do you have any suggestions?
    President:
  • 1,273 Answers
Trim piece covers a wide range.... If you are removing a knob, and have the screw out, try soaking with penetrating oil, let soak and remove by tapping side-to-side whike pulling straight out.
If you are removing a chrome (or similar) escutcheon tube (the tube that surrounds the valve stem, on tub faucets, a strap wrench works best. Since most folks don't have a strap wrench, you can pad the jaws of a pair of channel-locks and turn counter-clockwise to remove. An old belt with a rough finish works well as jaw padding. Just be careful to not press too hard, or you'll deform the tube.
Regards, --W/D--
Posted on Jul 21, 2009
How to replace dash lights on a 2001 grand caravan
First, you remove the center piece of the trim just in front of the steering wheel. This is best done using a trim stick or similar tool. There is a plastic grommet (mine was green in color) in the center of this piece holding it in place. A trim tool or flat head screw driver will help in this removal.
Then you will find 4 screws holding in the rest of the instrument panel trim. Two are underneath the trim you removed in step one, and the other two are at the top of the trim piece.
Now you can remove the cluster trim. But first. Did you set the emergency brake? If not do so now. Also did you disconnect the battery? No, well go back and do that also.
OK, now we can proceed. Put the key in the ignition, and turn to it to "ON". If you disconnected the battery the car won't start. I now this is obvious but to do the next step you have to disengage the lock on the gear selector.
Now, put your foot on the brake and and move the gear selector all the way to the lowest position. The trim piece should now move forward or towards you. Taking the right hand side move it towards the center council while pulling out towards you. You don't have to force it. Once you have this trim piece out place the gear selector back in park.
Next you must remove the four screws holding in the instrument cluster. They are placed in each corner. Be sure not to remove the screws holding the cluster faceplate. On the bottom they are right next to the cluster screws.
Now you are ready to pull it out and replace any bulbs as needed. Although they can be removed by hand, using pliers will prove far quicker and easier.
Re installation is the reverse of removal.
Read more: http://wiki.answers.com/Q/How_do_you_replace_instrument_panel_lights_on_a_2001_dodge_grand_caravan#ixzz1nH2WxS00
Feb 24, 2012 | 2001 Dodge Grand Caravan
Remove cd player/2003 toyota avalon xls
hi,
please state the problem completely sir.What is it that you want to do?
Jul 19, 2011 | Car Audio & Video
My 2001 Impala ignition won't turn when I insert the key. How do I replace the tumbler?
  • Open the hood and disconnect the negative battery cable with an adjustable wrench. Wait a few minutes before starting work to allow any current to dissipate. Set the parking brake.
  • 2 Tilt the steering wheel down to the lowest position. Move the gear shift lever to first gear. Leave the key in the ignition. Remove the lower under dash panel plastic clips and screws with a screwdriver. Lift the lower panel upward and remove the upper clips. Disconnect any electrical connections and remove the lower trim panel from the work area. Move the gear shift lever to the Park position and turn the key off.
  • 3 Remove the bolts from the knee bolster plate with a socket wrench and remove the plate from the work area. Remove the two ignition switch bolts using a socket wrench. Disconnect the electrical connector and remove the ignition switch.
  • 4 Install the new ignition switch using the retaining bolts and tighten with a socket wrench. Connect the electrical connector. Install the knee bolster plate and bolts using a socket wrench. Turn the ignition on and move the gear lever to first gear.
  • 5 Connect any electrical connections to the lower trim panel. Install the lower trim panel using the upper clips. Install the bottom screws with a screwdriver and insert the plastic clips. Shift the gear lever into Park and return the steering wheel to its normal operating position. Connect the negative battery cable with an adjustable wrench and close the hood. Release the parking brake. Start the engine to make sure the new ignition switch is operating properly.
  • Dec 04, 2010 | 2003 Chevrolet Impala
    Thermostat location and picture on a 2000 malibu running hot
    I have done many of these.The service manual will tell you to remove the exhaust crossover pipe. Please don't do this, you'll just be wasting your time. I always use a 13mm open end wrench and reach under and around the crossover pipe with my right hand with the wrench and my left hand i put in between the exhaust crossover pipe and the thermostat housing(the one piece you are referring to).The left hand helps to position the end of the wrench onto the bolt and holds it on while turning it. It will take a little while to remove the bolt, as there is not much room for the wrench to move, but it works. You also may have to keep flipping the wrench over to get it back on the bolt in the limited space.
    Aug 27, 2010 | 2000 Chevrolet Malibu
    Unable to crack nuts on rear wheels on old fergy 35 tractor.
    Lefty loosey, Righty tighty... is an old saying.. So unscrew is Left, Counter Clockwise. I have had to us a blow torch on then to get them off! use some WD40 OR CRC let it soak in a bit, and give the nut a few good wacks with a hammer. Use a real long lever too is another way, a piece of pipe over the handle works, but be careful you don't snap anything.
    Feb 06, 2010 | Tools & Hardware - Others
    I have a Moen Monticello bathroom faucet. I am
    Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
    Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
    Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Don't know how to change the lights on my instrument panel ... 2005 Jeep Grand Cherokee
    Although I've not changed these on this vehicle, I do know that most newer vehicles have changeable IP cluster lights that basically twist turn for replacement but you will need to actually remove the instrument panel (IP) cluster to access them;
    1. Grab a seat behind the wheel and lower your stearing wheel as low as it goes to get some room
    2. There is a dome shaped piece of trim surround your IP cluster, wiggle gently upward by grasping the top portion (two hands with your thumbs inside the lip of the trim and your fingers on top) until it begins to move, now look down to the steering column and you'll see the botom portion of the trim lifting, move one of your hands to it and using equal force top and botom, lift the trim gently up and toward your forehead to reveal the IP Cluster in its bare form
    3. Locate and remove the two screws at the top of the cluster
    4. That's as far as I can go at this point because all my tools are elsewhere just now, you should be able to go from there though, it's not overly complicated when you consider the fact that the factory building of these things has to be straight forward enough to move 1500 of these things down-line in an 8 hour shift!!
    Hope it works out for you
    Aug 01, 2009 | 2005 Jeep Grand Cherokee
    Unable to open the fuel door on 2002 VW Beetle!!! Any suggestions? Thanks
    The cause will be the cable that links the actuator to the flap is siezed.If you hook your fingers under the edge of the flap that pops up you can bend the flap (its plastic) so it clears the catch and it opens.it a fairly common problem.to replace it you need to remove several trims on the right hand side.Back panel ,lower c post upper c post and the rear headlining trim.they hook behind eachother so to remove one you have to remove another etc.hope this helps.Ocasionally the actuator itself fails so check it moves once the cable is disconected from it by operating fuel flap switch.cheers
    May 17, 2009 | 2000 Volkswagen Beetle
    Driver side wiper wont work
    One side does not work? Can you move the arm with your hands? If so, look for a loose nut that holds the wiper arm on. Remove the plastic trim on the wiper arm base, and tighten the 12 millimeter bolt. Please advise if this helps.
    Dec 22, 2008 | 2003 Toyota Highlander
    VW Passat 1.8T 1999
    Do you mean at the bottom edge of the door? If so, open the door and down in the lower front corner on the inside you'll see a screw. Take that out - it's the locating screw for the trim piece. Then from the outside, slide the lower trim piece rearward to disengage its mounting clips, and it should come off in your hands.
    Aug 28, 2008 | 1999 Volkswagen Passat
    Plumbing Logo
    235 people viewed this question
    Top Price Pfister Plumbing Experts
    bwbconstruct
    Level 1 Expert
    john h
    TED
    Level 1 Expert
    Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
