Question about Dell 944 All-In-One InkJet Printer
Error 1203, will not print only gives error 1203, no test will print
  • 4,041 Answers
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
What is error #1203?
MY PRINTER WAS PRINTING AND ERROR #1203 JUST CAME UP AND IT STOP PRINTING.
Aug 01, 2012 | Dell 946 All-In-One InkJet Printer
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
The printer read Cartridte error 1203 I am reading the manuel but I do not understand how to fix it to print. I do not have it connected to the computer I just want to make copies.
Are you using Dell Series 9 ink cartridges?
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cat ridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
Rick
May 30, 2011 | Dell 926 All-In-One InkJet Printer
Lexmark printer problem. Printer is not printing shows error 1203
Hi
Error 1203 Dell 962
There can only try and I hope it will do the job for you.
or
press copy
you may need to Reset Factory Defaults
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Be sure not to leave any debris of klennex on those holder contact panel.
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
please send me info to solve the problem on my fax
23768838.jpg Error 1203
Jan 17, 2008 | Lexmark X4250 All-In-One InkJet Printer
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Dell 944 All-In-One InkJet Printer Logo
178 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
