Question about Harman Kardon HKTS 2 Speaker
The sub has a loud buzzing when turned on (harman kardon hkts 2
  • 158 Answers
Sounds like your audio stage is blown
Posted on Jul 22, 2009
WHY is my harman kardon HKTS 15 subwoofwer is making a booming sound
Disconnect the cable and check the impedance/ohms with a meter.If rated at 4 ohms then it should read near that value.For 8 ohms also the reading should be near that value.You can buy a cheap Volt ohm meter for under ten dollars.After taking the ohm reading,it will be easier to diagnose................
Aug 19, 2014 | Harman Kardon HKTS 14 System
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
Hello, my Harman Kardon HKTS 15 sub woofer don'st work, the light that suppouse to turn from orange to withe when i turn on my receiver stay orange.could be the cable from my receiver to the sub...
It could be because of your subwoofer AMP is gone.
Temp fix: Disconnect the subwoofer wire from receiver for 20-30mins and plug-it back. It did work for couple of months.
Aug 22, 2011 | Harman Kardon Audio Players & Recorders
Where can I find sub board assembly for Sub-TS5. Part # 104SUB13500
If you haven't already found one, there is one currently on Amazon. It is pretty pricey at $50, though. You'd be better off buying a new sub.
http://www.amazon.com/104SUB13500-GEN-POWER-ADAPTER/dp/B004VETBPG
Aug 08, 2011 | Harman Kardon HKTS 5 System
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
The subwoofer on my HKTS Home Theater Speaker
Hello Ennisfamily,
Typically these noises "present" when CHEESY
capacitors... fail:
(what I lovingly call "GUM-WRAPPER") break
down... FAILURES are an ECONOMIC choice of
the manufacturer (in my trained & experienced opinion).
Although SAMSUNG has gotten most of the attention
... Most major manufacturers of CONSUMER grade
"entertainment" equipment GLEEFULLY pocket a few
extra cents for EACH high-grade (MIL Spec) QUALITY
capacitor... THEY DO NOT BUY...!!
Funny: (SAMSUNG kit available on AMAZON
(electronic handling SKILLS & tools are required)).
WITONICS Samsung LCD Plasma TV CAPACITOR Repair Kit Replacement Parts...
I would ONLY say SAMSUNG is certainly NOT ALONE
in the egregious (my opinion ... again) behavior.
Yes... CERTAINLY REPAIRABLE
Thou shalt not...
open electronic enclosures without "static protection"
Calunce Velcro ESD Antistatic Wrist Strap With 2 5M PU Adjustable...
Hope this helps
Carnac the Magnificent
Nov 11, 2017 | Harman Kardon HKTS 14 System
Harman Kardon HKTS 2 Speaker Logo
1,099 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
