Question about GE AJCQ08ACB Air Conditioner
GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
I have ran this window unit for several hours for several days however on it's own time frame it shuts off and trips the reset plug. I have tried it in several outlets and still does the same thing....shuts down and has to be reset. Any ideas on what to check for?
  • 227 Answers
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Posted on Jul 20, 2009
Unit runs for hours then power goes away, breaker not tripped
Possibly a backed up drain, possibly loose/melted high voltage wires just not tripping breaker, possibly wrong size breaker
May 29, 2017 | Heating & Cooling
Premature power down.
Check for loose or corroded power connections.
Jul 12, 2013 | Lowrance LCX-113C HD GPS Receiver
Keeps shutting Down
Have to start at the beginning---Lamp? Ballast? Color wheel?
Jun 07, 2012 | Samsung HL-R6167W 61" HDTV
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
When I plug in the unit it trips the reset button every time. Its
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Jul 25, 2009 | Heating & Cooling
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Freezes on 'Samsung' screen
While the unit is connected to the PC, hold down the RESET hole at the back for 10 seconds.
Mar 23, 2009 | Samsung YP-Z5FA MP3 Player
Burner will run for a couple of hours and then turn off.
They could have disturbed the sludge in the tank when refilling. If you do not have a filter in place it may have clogged the pump or jet and making it hard to start. These need yearly maintenance anyway. The pumps usually have a screen inside and the jet has a screen inside. First,open the bleed on the pump and purge some oil from the line and see if it is flowing freely. If so, the take the drawer assembly out and clean it. Make sure the jet is clear, by blowing through the attached oil line. You should see/feel a fine mist of oil come out. Electrodes should be about 5/32" apart for an F5.
Jan 14, 2009 | SySTOR Systems (400S52) Burner
Frigidaire freezer quits running
actionsnax please remove the freezer from the GFCI. What is happening on this old unit is that if the compressor shuts off then tries to come back on before the pressure in the system equalizes, the compressor can pull 12 amps. This is normally higher than the trip point of the GFCI. I had this happen years ago with a brand new Amana SXS refrig, in that case no one knew the unit was on a GFCI. The manufactures require that this units not be on a GFCI.
Hope this helps
Feb 01, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
GE AJCQ08ACB Air Conditioner Logo
500 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Mack Baxter
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
