Question about Adobe Photoshop CS3 10
I have a DELL 2407WFD-HC Color Monitor which I am now calibrating with a SPYDER3PRO. Spyder3Pro has asked if the monitor has: 1. Kelvin Presets, 2. Kelvin Slider, 3 RGB Sliders. I can't find this information in the manuals.
  • wayne428 Jul 20, 2009
    Thank you clear answer to my problem
  • 19,396 Answers
Kelvin preset and Kelvin slider are adjustment of color temperature.
Kelvin adjustment changes colors by changing the white balance, while RGB acts on red green blue percentages.
Dell monitors have no kelvin presets, but they act on RGB sliders (RGB regulators) that will do the same thing in a different way.
Regards.
Posted on Jul 20, 2009
Monitor color settings not being maintained
Sorry to hear you're having this issue, Josh. To clarify, you can get the proper colors if you set them manually, correct? If so, that rules out the possibility of a screen issue or a problem with the video card. I hope for your sake this is a new monitor for you (or at least one that would still be covered under warranty), for it sounds like it's a logic issue in the monitor itself that prevents saving of the proper settings as well as the distortion of the presets. I would return it if possible for a replacement/refund, as they seem to be a quality product...it just looks like you got a defective one. Sorry I couldn't be of more help to you, but good luck! :)
Nov 07, 2013 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Color temperature
If the monitor was set correctly at the factory, the color temperature should be close to whatever temperature the calibration tool reads. Your assumptions are correct as to the usual settings. Sometimes warm is near 4000k.
Jul 04, 2017 | Acer X183HB Monitor
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Colors have gone wrong
There could be 3 reasons for this...
1. If color settings are changed from the computer...
try to reset to defaults
2. if colors are changed from monitor..
try to reset to factory defaults
3. If the Monitor cable is loose..
try differnt monitor if available with the same cable which is used to connect monitor and computer, or try using different cable on same monitor and computer.....
Nov 02, 2008 | Dell E176FP 17" LCD Monitor
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
All three LED's blinking, no video
hi, does the three lights blink only after u connect it to a display card??if yes then check if any of the connecter pins are damaged, or check out the display card..bye let me know
Dec 08, 2007 | Dell E173FP 17" LCD Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Adobe Photoshop CS3 10 Logo
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
