Konica Minolta Bizhub C353 Color Copier Printer Scan Fax Logo
I
Ime Lawson Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i print single color (cyan) from c353 bizhub?
rajeev pal
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 79 Answers
  • Posted on Dec 14, 2016
rajeev pal
Expert
Level 2:
New Friend:
Cheetah:
Answers
79
Questions
Helped
49866
Points
101
Use single color function-select cyan
When I make color copies the output copies are black&awhile pls help
I suggest checking the printer setup on your computer to determine if the default is black/white. On my Windows 10 computer, the color printer default can be changed between color and b/w.
My konica minolta c353 the screen is not displaying
See if you can get a new control panel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
C353 printing blue pages
replace the cyan image uit
C353 takes a long time to warm up and print
you can update the firmware, but it s not an easy way to do. It can help.
I have Konica Minolta bizhub C353 and the paper keeps getting jammed after several prints. I just cleared code error c-3421 but it keeps getting jammed. Any help.
First Are informing the copier of the proper paper weight
? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also.
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook.
1helpful
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
