Sony BRAVIA KDL40VL160 40 HDTV LCD TV Logo
R
Ray Balmer Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sony LED tv model kdl40vl160. The left side picture is dark but the right side is good. what can be the problem?
Lawrence Oravetz
Level 3:
  • Sony Master 10,558 Answers
  • Posted on Nov 29, 2016
Lawrence Oravetz
Sony Master
Level 3:
Answers
10558
Questions
Helped
2699994
Points
29284
T-Con board is going bad. It needs to be replaced. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
3 Related Answers
Anonymous
  • 201 Answers
  • Posted on Mar 06, 2010
SOURCE: my sony's picture is scrambled on the right side.
Is it like that on all inputs and does it affect the tv menu ? If it does the panel is bad, if you don't have a warranty on it it will be cheaper just to buy a new tv (sad to say). I would check out sony's website they might have an extended warranty on panel. Good luck!
Anonymous
  • 178 Answers
  • Posted on Jun 17, 2010
SOURCE: Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
Anonymous
  • 14553 Answers
  • Posted on May 17, 2012
SOURCE: left side is dark and right side is good
The LCD sets use backlights and also a pair (some models combine both into one unit) of inverters- one drives left side and the other right side.
You could have a bad inverter (some versions call it T-con) or even a bad display panel(main screen unit).
In most cases this is not a do it yourself repair.
2answers
Dark screen left side right side shows good picture how do I fix the problem
That could be a number of things. Possible ribbon cable loose or sweep or memory board faulty. Also I would not rule out a break on the screen. Good luck
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Sony Brovia TV the picture went dark. You can see it but not to well.
Picture Become dark means there is some problem with the back light of the tv. can be problem with the back light led drive or the led array.
www.electro-medical.blogspot.com
Why is the picture on my Sony KDL-46VL160 good on the left, dark in the center and distorted with slow refresh to the right?
Back-light problem. Contact the authorized service center for Sony.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sony tv troubleshooting
Hi, Please try to push or move the frame of your tv set on the dark side of the picture. If the picture becomes normal it is the loose connection. Otherwise it may be panel failure. Please consult some qualified technician or the service center.
Left side is dark and right side is good
Sony tv kdl-46vl130, Turn the tv on, half of the picture is dark, leave the tv on for about 20 minutes, and the tv is perfect, and stays perfect no matter how long is watched, Turn the tv off, and come...
I didn't look up the model to see if its a LCD or LED, if its an LED it sounds like you have some lamps going out, try turning down the backlight settings and see if that helps
3answers
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
