Question about Garmin GPSMAP 60CS GPS Receiver
Garmin not acquiriing satillites
Hi
I have had my Garmin now for a couple of months, Changed the batteries cause they were flat , went to power it up again and it wont acquire satillites. I have no pictures of satillites or the strenght bars.
  • 3 more comments
  • hoff5104 Dec 22, 2007
    My Garmin cannot acquire the satillites. So I did some of the solutions and went to garmins website and downloaded the web updater. It said that I have the most current software/chip. It shows me having the 3.50. After i did that, I then turned on my unit and it shows absolutely no satillites on the acquiring screen or strengh bars!!!!!! Now it's really broken. help me please!
  • Anonymous Jun 03, 2008
    Yep. I have five of these units and one of them just crashed in the same way. I know someone else this just happened to as well. GPS is definitely on 'Use with GPS on', but can't see any satellites and it claims it is 'Aquiring Satellites' but nothing ever happens. Have updated the software but still no luck. Any ideas anyone? I am living in Vietnam and sending units back to the states is not really an option.
    Cheers
    lohasfklA
  • MALCOLM16 Jun 29, 2008
    Got unit back from factory after supposed refurbish. Seemed to work fine. Then it quit acquiring satellites. Updated to latest version. Nothing happens.
  • karso_no Oct 16, 2008
    My Garmin GPSmap60CSx not aquiring satellite
Go to the Garmin Website and do an update. Make sure that you get GPS Chipset Type G update it is seperate from the regular update. This fixed my problem with never aquiring satellites.
Posted on Jul 20, 2008
  • 22 Answers
Hi
possibly the unit is set to 'use with gps off' mode
go to the satillite page and hit menu
select use 'gps on' then enter
make sure you let it re-find the satillites again before you move off
D
Posted on Nov 21, 2007
On My garmin gps 72H none of the buttons will work. EG I cannot change pages or turn off. Was working fine then changed batteries and this occured. Any suggestions??
I would read the owner manual first and then remove the batteries for a while and put back. This does not use recharge able batteries?
Nov 03, 2012 | Garmin GPS 72 GPS Receiver
Garmin nuvi 1300lmt telling me to turn on streets that are not there, taking awhile to accquire satillites.
Make sure that your GPS unit has a clear vision of the sky. Usually sitting on your dash will be good. Finding the Satillites from a full power off can take anywhere from 1 to 4 minutes. Also, any outside obsticles can hurt GPS coverage such as trees and tall buildings.
As for the maps and being told to turn on wrong streets: I have had this happen too but not very often. Our roads are consistently being changed and the maps take longer to be upgraded.
This is not really a sollution but more of an explanation.
Jul 11, 2011 | Garmin nuvi 1300 Car GPS Receiver
My Garmin GPSmap 76CSx was working just fine. After leaving it unused for a couple months with a pair of alkaline batteries installed, I tried to turn it on. It would not come on. I checked the battery...
Try connecting it to USB and powering it up, to confirm that unit still works overall. You probably damaged battery connectors. Check if you can clean the connectors better, otherwise you may need to do some soldering to fix them, by yourself or n a repair shop. Check with Garmin if they have suggestions: a leaking battery should not disable a GPS.
Dec 10, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Just quits
I had the same problem (blank screen, vertical line). Per Garmin, turn off the WAAS function. Disable it for now, because the government has changed the WAAS signal coming from the satillite, and Garmin has not yet come out with a remedy to correct this problem yet. It should be out in a software update sometime in the future...............I did this and it corrected my problem immediately. The unit performs perfectly now, however, the accuracy is not as good, due to the lack of WAAS.......................
Dec 04, 2008 | Garmin MAP76 handheldS GPS Receiver
Question mark on screen
An external antenna should solve the problem.
Jun 18, 2008 | Garmin StreetPilot c550 GPS Receiver
Powerless garmin
When leaving the unit not powered up for so long, the internal battery may be damaged. The power supply will not start up if the internal battery is defective.
Sometimes the internal power supply may become defective in this case and must be replaced along with the battery. Contact the manufacture for details about how to get the unit serviced.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin 60csx that won't power up
On my GPSmap 60CSx the screen fades away after powering on - just like the battery is empty. Changed battery and used USB power. Always the same. When removing  the 2GB micro SD memory card then it comes up. Replaced the memory card and now it powers up fine. Seems that the memory card is damaged or causes a short circuit.
Apr 26, 2008 | Garmin GPSMAP 60CS GPS Receiver
Distances are WAY wrong.
hi
before you start running make sure you take the unit outside into the clear for a few minutes, dont just start running from inside a building or a new location
erase the track log if you can so that the data is only resuts from the current run
make sure you check the signal for the next few runs
(also run a few extra for me)
D
Oct 03, 2007 | Garmin Forerunner 301
Garmin GPSMAP 60CS GPS Receiver Logo
189 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
