Question about LG 42PG20 42 in. Plasma HDTV
42 LG plasma no picture but sound. found internal fuse had gone so replaced. Then when switched on it stays on for about 5 seconds and switches itself off again. Replaced power supply and now when switched on it tries to come on then clicks and goes back to standby and red light is on. any Ideas
  • Anonymous Mar 14, 2014
    have a samsung ps42b430p2w plasma tv.when i try to switch it on it just continously clicks.what board are the 2200uf 16v 105 c capacitors on.not sure which board the power supply board is
    President:
  • 1,077 Answers
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
42 LG plasma no picture but sound but it stays on for about 5 seconds and switches itself off again. Any ideas???
Power supply is probably bad. You can check the capacitors inside the power supply for bulging on the ends. Very inexpensive repair.
Feb 25, 2011 | Televison & Video
Sound but no picture
It's very likely the fuse on the Y-sustain board may have gone open circuit due either a fault with the sustain board or the buffer board. If this is ok then check if your Vs & Va voltages are present when switched on if yes you may have a fault with the control board.
Jun 21, 2009 | LG 42PC3D 42 in. Plasma Television
No picture or sound.
Replace ysus board!!
Check all supply rails before replacing,
Cheers
Apr 02, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
I have a plasma lg 42PX5D tv as with other problems it went pop yesterday. took back off and found one of the fuses had gone -------- got replacement and the turned tv back on more poping sounds ----- re...
This is a common problem with any make Plasma, chances are the Y sustain module has gone bad. Sometimes it takes 3 separate modules by recommendation from mfg's to be replaced at the same time. Let me know what you have done with this issue please?
Feb 02, 2009 | LG 42PX5D 42 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42PG20 42 in. Plasma HDTV Logo
922 people viewed this question
