Question about Ruud Central System Air Conditioner
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
  • 614 Answers
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Posted on Jul 21, 2009
How many tons is a rudd model ubhc-14j06sfd?
I believe the "06" in the model number has been reversed. It should read UBHC-14J60SFD. This would make this unit a 5 ton unit. I hope this helps:) Have a great day!
Jun 18, 2014 | Ruud UBHC Air Conditioner
Have a R-22 Rudd ait handler. Replaced the compressor with a 1.5 ton Goodman unit. My home is 1300 SF in NJ On hot days during the peak of the day the system seems to stop working for a period. The...
If your home is 1300 square feet 1.5 tons is not going to cut it you should have at least 2.5 ton A/C unit. sounds like your system is to small. let me know if this helps you out.
May 12, 2011 | Ruud UAKA037 Air Conditioner
I have a 5 TON Ruud split unit air conditioner.The Compressor was replaced last year.Now the unit works well for about 15 minutes and then stops cooling. Thermostat says,"In Recovery". What can I do to...
May be due to improper refrigerant pressure; I would have it checked.
'Recovery' is normally provided to allow high- and low-side pressures to return to a safe range before the unit is allowed to cycle again and yours is doing it way too soon.
Aug 07, 2010 | Ruud Central System Air Conditioner
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Ruud 4.5 ton unit comes on but the compressor is noisy and it does not cool house....can compressors be replaced or can you put more oil in them....where can we purchase A replacement...
First, check the age of the unit. If it's less than 5 years old, the compressor may still be under warranty. You would be responsible for the labor portion.
Replacing an A/C compressor is not simple and requires special tools and training. Almost any local competent A/C shop should be able to replace a compressor if that is the problem.
You might want to call for service first before going any farther.
Jul 07, 2010 | Ruud Central System Air Conditioner
What size is a Rudd UAKA-048-JAZ?
it is a 4 ton and should cool your home if it is working properly
Jun 15, 2010 | Ruud Central System Air Conditioner
Noisy outside from the Unit
Could be compressor noise Improper charge bad fan motor hard to say. What is the brand name of your unit. Russ
Jul 20, 2009 | Ruud Handle Air Conditioner
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
Ruud Central System Air Conditioner Logo
242 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
