Question about Amana AFD2535DES French Door Refrigerator
Water dispensor not working in door
Water is not coming out and not filling ice maker, we changed water filter, but that didn't help
  • Anonymous Aug 16, 2008
    ice maker will not fill with water
  • Anonymous May 22, 2009
    ice maker not working
When the chicken crosses the road!!
Posted on Jan 30, 2008
How do you know when you need a filer
Posted on Jan 13, 2008
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
I have a Kenmore side by side model # 25358672894. i have water flow through the door dispensor but no water to ice maker. i checked the fill tube and it is not frozen. the temp in freezer is 0 degrees....
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Apr 18, 2011 | Refrigerators
The ice maker stopped making ice. Any solutions?
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
Oct 23, 2009 | Kenmore Refrigerators
The water dispensor just stopped working today. The ice maker seems to still be working. What should I do?
I JUST CHANGE MY FRIGH FILTER BUT WATER DOSE NOT COME OUT THE FRIGH DOOR ONLY ICE. ITS A GE
Oct 02, 2009 | GE GSS25JEMWW Side by Side
My ice maker stopped making ice all the sudden. there is no water in the ice maker
do you have a water dispensor in the door? if you aren't getting water check the filter. if the water line is not clogged you may have a bad water fill valve or the motor/gear in the ice maker is bad.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice
Sounds likw the water fill tubs is frozen shut, look where the tube comes into the freezer compartment and take a hair drier and thaw it out. Good Luck
Jan 07, 2009 | Kenmore 53642 / 53644 Side by Side...
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Amana AFD2535DES French Door Refrigerator Logo
178 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
