Question about Haier Heating & Cooling
We have a wall mounted Hair air conditioning unit and the error code E7 appears on it yet the manual has no error code E7 in it
This is a communication error between the indoor and out door units.
Posted on Jan 06, 2010
I need error code manual for Dometic Air Conditioners RV roof mount
https://www.dometic.com/8dc07cfd-4b72-4069-9205-af83e4e0084e.fodoc
Jul 26, 2014 | Dometic Rooftop RV Air Conditioner
E7 Error Code on BladeZ Fitness Powermills Treadmill
Hello, E7 error means:
- Elevation Motor Elevation Motor out of
Range
Replace Elevation Motor
- Display Doesn't Lit Up
On/Off switch Check if unit is turned on
Insufficient Power Source Plug unit in a dedicated
120V, 20Amp Outlet
Line Cord Damaged Replace Line Cord
Fuse Check Fuse on MCB
Here is website with users manual and troubleshooting>
H http://www.treadmillfactory.ca/support/635-640.pdf
May 19, 2014 | Bladez Exercise & Fitness
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Works manually but not with remote, E7 code keeps appearing
E-7. This is a communication error between the indoorand out door units.
Check your wiring . Split and Multi - check voltage from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 07, 2011 | Heating & Cooling
Hi my copier displays E7
Check this out :
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the **** glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
E7 problem
E7-02: LSU trouble
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
"1" key, "4"key
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Heating & Cooling Logo
1,695 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
